Results 1 to 10 of 10
Thread: To add calcium or not to?
    May 2013
    Miami, FL
    23
    My calcium is currently really low at 150. I suspect its there because 1) the plaster was redone in 2011 2) the pool was topped off with softened water.
    I just recently connected to city water, (i still have my well, but no longer have the water softener hooked up). The well water is hard and the city water is also hard (so i think they're both high in calcium).
    The question is, do i continue with really low calcium levels and wait to see if the city & well water raise the levels as I top off? Or is it low enough that i should add calcium now to protect the surface?
    really happy to have found this forum
    pool owner since 2012
    13-15k gallons, kidney shaped,in-ground plaster
    1970s construction, currently undergoing complete renovation
    3 jets, 1 skimmer, 1 dedicated vacuum line, kreepy krauly great white, main drain
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: To add calcium or not to?
    Welcome to tfp, tmnt25
    Quote Originally Posted by tmnt25
    We need a full set of test results including pH, TA, CH, CYA, Temp, Borates (if any purposefully put in), Salt (if any purposefully put in) in order for us to really know. The recommended levels are 250-350 ppm, but in your high CH makeup water case, that range may not apply directly. Do you know your fill (makeup) water CH level?
    Butterfly's Avatar
    South Carolina
    10,045
    I suggest you test the city water for calcium now.
    Welcome to the forum
    You're done SLAMing when:
    May 2013
    Miami, FL
    23
    Quote Originally Posted by linen
    based on pinch a penny:
    FC 5
    pH 7.6
    TA 100
    CYA 60
    Don't know about borates, salt. i currently have a pool service, but am not confident they are doing a great job. He only tests with strips and given what i've learned in pool school, this is not sufficient. Also, some metal stains he's ignored has caused me to go on a learning spree.
    will pinch a penny test my water source?
    looking into buying the k2006 or the tf100
    I'm in miami, fl.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Pinch a penny will test whatever you bring in ina bottle. They don't know if it's from your pool, your neighbor's pool, or the tap. But they need to test CH for you.
    Butterfly's Avatar
    South Carolina
    10,045
    The TF100 is the fav around here. More bang for the buck, great customer service, same taylor chems, and hands-on help from the owner
    Vette's Avatar
    Jul 2012
    Ohio
    404
    Honestly, getting a test kit like the TF-100 or K2006 is the best investment you can ever make in your pool. Even more than any equipment upgrades.
    11,700 gallon 21' round 54" deep all-resin AGP - June 2012
    Waterway 1HP 2-speed pump / 100 sq ft cartridge filter
    Hayward 150,000btu Natural Gas heater
    I use and recommend the TF-100 for testing
    May 2013
    Miami, FL
    23
    Quote Originally Posted by Vette
    ordered the tf-100 2 minutes ago
    you all are great salesmen....
    I do have an over the counter test kit that gave me similar results on FC, PH and TA that pinch a penny gave me.
    May 2013
    Miami, FL
    23
    Just got my TF text kit and got the following results.... Really different than pinch a penny
    FC 11
    Cc .5
    Ph 8
    TA 80-90
    CH 140
    Cya 30
    The cya test is real difficult, am I not supposed to see the dot at all?
    38,524
    No sign of the dot.
    Check out the extended testing instructions sticky in the testing forum.
    Looks like you should lower the pH and raise the CH a bit.
