Thread: Stainless steel brush on tile
    May 2013
    Egg Harbor Twp, NJ
    41
    I've been starting to use a stainless steel brush on my pool to get rid of some calcium build up. Is this type brush ok on the tile and grout or should I try to avoid contacting those areas with it?
    Thanks!
    25,000 gallon IG gunite pool with Diamondbrite finish built May, 2012
    All Pentair equipment:
    FNS Plus 48 sq. ft. DE Filter, 1 HP SuperFlo Pump, IntelliChlor IC40 SWG, MasterTemp 400k BTU/HR Heater, Prowler 820 Vacuum
    Test Kit - TF-100
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Re: Stainless steel brush on tile
    If it's a pool brush, it should be fine. Stiffer, thicker wire brushes can chew things up pretty good. Ask me how I know.
    If you have a white ring around the tile at the water line, a pumice stone and elbow grease will get rid of it. Follow it up with Motrin and/or alcohol.
