Results 1 to 7 of 7
Thread: Hope I'm doing it correctly, New to BBB this year
    Hi there,
    Thanks in advance for your help.
    We opened our pool 5 days ago, and I would like to try BBB. I usually use 3" tabs in the auto chlorinator, and was limited with funds so I bought the HTH small canister. What a waste of money! dissolved all 11 or so tabs in 5 days. I'd like to try the BBB method which I've read about here for the past 4 years but want to know if I'm doing it right.
    Took cover off, gross almost black water. Cleaned our DE filter, added back DE, and shocked. Backwash was crazy, needed to be done often. Took filter apart again, hosed it off, replaced DE.
    Started to turn light green, Shocked, vaccumed, got leaves off bottom.
    Every time I would shock (two bags of the HTH super) I would get a high CL reading, then an hour later back to nothing.
    Back out there today (in the rain, talk about dedication!) Pool definately lighter green. Vaccumed, brushed, shocked. This time when I measured 2 hours later the FC was 10.
    I'm hoping I'm on the right track. Here's my numbers.
    FC 10
    PH 7.8
    TA 80
    TH 200
    CYA 30
    22,000 Vinyl with DE filter.
    If I understand correctly, if the FC holds, and water clears, all is good?
    I then have to figure out how to add the bleach to the water for maintenence. I have 8% bleach. I tried the pool calc but hate to say that I'm just no good at figuring it out, sorry.
    Thanks so much!
    38,537
    Re: Hope I'm doing it correctly, New to BBB this year
    Welcome to TFP!!!
    Have you read Pool School? Specifically these:
    Defeating Algae
    Turning Your Green Swamp Back into a Sparkling Oasis
    Shocking Your Pool
    What are you using to do your testing? Does not sound like one of the recommended test kits that contain the FAS-DPD chlorine test.
    The BBB method is really just about understanding your pool’s chemistry and through accurate testing, adding only what the pool NEEDS.
    Using 6 way strip while waiting for my Taylor test kit.
    Any advice in the mean time would be great!
    I have read the recommended links, thank you. It's how I am getting the courage to get away from the pool store
    38,537
    Hard to actually believe any of the numbers from a strip test. I would just continue to monitor the FC and keep it around the max of the strip and when your REAL kit arrives, do a full set of tests and post the results.
    You need to pass the 3 criteria in the Shock Process article to know when the process is complete ... but you need the FAS-DPD in order to check those criteria.
    Butterfly's Avatar
    South Carolina
    10,045
    You need to re-read the links blizzle gave you and understand the "shock process". See red lines in my sig.
    No problem. Assumming 22K gal pool and 8% bleach, each quart will add about 1 ppm FC. Just test, determine how many FC you need and multiply by one quart-ish. That's all you need to remember for maintenance.
    You're done SLAMing when:
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Welcome to tfp, Myrose
    jbliz and BF gave you some good advice, make sure you read those pool school articles!
    Quote Originally Posted by Myrose
    If you can cancel that order, the tf-100 usually ships faster and is a better value.
    Read the shocking article jbliz pointed to, it is slightly more detailed and concrete than that, particuraily CC<0.5 and an Overnight chlorine loss test (OCLT) of <1 ppm FC.
    Thanks so much!
    Going to read the red highlighted articles now.
