Thread: concrete coating
    Mar 2012
    Just South of Atlanta, GA
    18
    concrete coating
    I have read about the "Shark Grip" that you would mix with the poly to make a none slip surface.
    Question is, can the shark grip be mixed by me at the pool or does it have to be mixed at store with the machine ??
    Silly I know, but home depot said they would not mix it..
    16 x 36 IG Vinyl 27,000 gal, AutoPilot DG-220 SWG RC-42, Dolphin Premier bot.
    Re: concrete coating
    I mixed mine at home by hand and it worked fine.
    u can mix it yourself before application. just make sure your keep it mixed throughout the application, it will settle to the bottom if not.
    10,000 gal ag intex krystal clear pump 633t and cartage filter
    Mar 2012
    18
    Super ! Thanks
