Thread: CYA way high
    CYA way high
    Finally got my test kit. Results as follows:
    FC = 37 CC = 0 TC = 37
    pH = 7.5
    TA 210
    CYA (off the scale)
    I mixed 10ml pool water with 90ml distilled water, repeated the test. Result was 30 (x10 = 300)
    Repeated the all tests with same results.
    Plan to remove and replace much of the water. I can probably draw down 2/3rds of the volume of the pool with my lowest intake.
    Any reason to not do it this way (removing so much water all at once?)
    Sacramento CA
    33,000gal, IG, circa 1970, (now) fiberglass over plaster, pac-fab paper cartridge, 1.5hp pump, polaris 280 (inoperable, UV damage) with booster, solar heat (inoperable, leak in powermat), skimmer (inoperable, line clogged & possibly fractured under concrete), main drain inoperable (long standing problem), jury rigged deep intake, skimmer line work-around in progress.
    Casey's Avatar
    SW PA
    10,427
    Re: CYA way high
    Leave a ft of water in the shallow end. It's to dangerous to drain any more than that.
    30,413
    Re: CYA way high
    Yeah, I think I would remove not much more than 1/3 at a time. If you do the math, the extra water is not really all that much.
    Unless you live near a swamp with a VERY high water table, probably a 50% drain is also perfectly safe.
