Results 1 to 9 of 9
Thread: I am about to convert my pool from Baquacil to Chlorine
    lp232531's Avatar
    May 2013
    East Windsor, NJ
    3
    Hello,
    Thanks for such a great website. I am a beginner and am about to convert my pool from Baquacil to Chlorine using directions from the Pool School. I have a couple of questions regarding chemicals. Would I be able to maintain my pool using liquid chlorine/bleach, Borax, and CYA? Should I purchase Muriatic Acid instead? I am going to try to avoid the pool store and purchase chemicals from home improvement stores etc. Is this possible? Thanks so much!
    Beginner pool owner with a 18'x34' kidney right 3.6'x7' deep 20k gal IG vinyl pool built in 1991, Pac Fab Nautilus FNS-36 DE filter, Pac Fab Challenger Medium Head 1 HP pump, formerly Baquacil (in process of converting to Chlorine), Nitro robot vacuum.
    lp232531's Avatar
    May 2013
    East Windsor, NJ
    3
    Re: Have used Soft swim products for 12 years, tired of it
    Here is my pool.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: I am about to convert my pool from Baquacil to Chlorine
    Welcome to TFP.
    Every chemical has a different function, and whether you use them or not depends on your test results. Borax raises pH, while muriatic acid lowers it. Some pools tend to have low pH and some tend to have high pH, so your chemical needs will vary depending on the chemistry of your water. Our philosophy centers around knowing the chemistry of your water and understanding the effects of chemicals you add I can seem a little complicated at first, but with a little knowledge it's actually much simpler than conventional pool care.
    lp232531's Avatar
    May 2013
    East Windsor, NJ
    3
    Thanks for the feedback. I have a question about pH lowering. Should I use Muriatic Acid as the acid to lower pH (if needed of course based on testing results) or should I purchase another product?
    38,283
    Muriatic is the cheapest method of lowering the pH.
    Do not try to stock up chemicals. Just buy what you need. Eventually you will get a feel for what your pool typically needs and can then stock up some.
    Smykowski's Avatar
    Sep 2011
    3,065
    Yes. MA lowers pH. It's important to know the strength,which will be on the label, and can usually be found in the paint section of big box home improvement or hardware stores.
    Since you don't know what your pool needs yet, don't buy anything yet. What you can do is start pricing bleach/liquid chlorine, baking soda, stabilizer, muriatic acid, and borax. It will give you a good idea of prices, so that when the time comes you can pull the trigger on what you need knowing you're not getting ripped off.
    May 2013
    East Tennessee
    57
    i got CYA or stabilizer at lowes 3lbs $14 on memorial day !
    24' 13,500 gal round AG 06/01/2012
    hayward 1.5 dream line sand filter
    TF 100 !
    Mar 2013
    Western KY
    14
    I had a kitchen sink clog so I bought 2 bottles of that hot power or liquid fire or whatever it is called, but I only used one. I believe it is basically muriatic acid, so could it be used in the pool to lower pH?
    18k Gallon In-ground, vinyl liner
    Sand filter
    1hp one-speed pump
    38,283
    Quote Originally Posted by rkhodges21
    It depends what the chemical actually is.
