Thread: Pressure Gauge Problems?
    May 2012
    NE OK
    54
    Normally my pressure gauge runs at 12-13 psi. It started out there this year but through the pool opening process it has moved up to 20-21 psi. After backwashing and rinsing, it only drops down to 17-18 psi.
    Is this something I should be concerned about? I called the pool store and they asked if I put the pressure gauge inside for the winter. I hadn't. They told me because of that I need a new pressure gauge. Wanted to check with my trusty pool forum before I changed the pressure gauge. Is there something else I need to be doing/checking?
    25,000 gallon
    AG
    Sand
    filter size is 26 diameter
    flow rate 70 GPM
    AG Pool (33ft.) was newly installed in spring 2011
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Pressure Gauge Problems?
    You probably do want to put it inside for the winter. Does your gauge go to zero when the pump is off?
    May 2012
    NE OK
    54
    Just went outside, turned it off and it drops to 5psi when off.
    25,000 gallon
    AG
    Sand
    flow rate 70 GPM
    SW Indiana
    9,199
    Quote Originally Posted by curlyfry22
    Time to replace it. They are cheap. i usually get mine at a farm store because they are better quality and you can get larger gauges. Just be sure to get the 0-60psi range rather than the 0-120 or 0-200psi ranges so it's easier to see minor pressure changes.
    May 2012
    NE OK
    54
    Ok, thanks!!!
    25,000 gallon
    AG
    Sand
    flow rate 70 GPM
