Thread: Shocking process. 2 of three steps
    Hello:
    had 1ppm change overnight.. water did not turn pink (CC's) but the water is blue but I can just barley see the bottom. It is very cloudy like it needs a clarifier. My questions is is clear meaning totally clear or might this be all the dead algea. I just repalced my cartridge so I was hoping that will help. Continue to shock untill I can see the bottom clearly. Will clarifier help or waste of money.
    thanks
    17100K AG v. liner Pentair Tropicana 2HP pump Cartridge
    22,543
    Re: Shocking process. 2 of three steps
    how long have you been shocking?
    Clarifier is one of those things that might work or it might not do anything. I suggest to give it a couple days after passing the FC loss test and the CC test before considering even trying it. However, it won't really hurt anything if you do.
    May 2012
    Greensboro NC
    88
    I am in a similar situation.
    I know the process can take a long time, from experience, to go from cloudy to clear. Want to try clarifier so I can try to get results, just don't know if it is wise.
    24,000 gallon
    Vinyl Liner
    In Ground Pool
    Hayward super pump 1hp
    Hayward S220T 250lb. Sand Filter
    I have been shocking 5 days. Let it slip below 12 a few times but have been keeping it up. If it will not hurt anything I might at some to it.
