Thread: Liquidator Flow Indicator
    Liquidator seems to be running well now, all the soda fizz bubbles seem to have just been parts out gassing etc, because all the lines are now solid and the water is running well.
    I am holding steady with my chlorine in the pool (well, except for dealing with the storms every day), so I know I'm getting chlorine in. But I'm wondering if my flow indicator is working properly. You can see from the flow indicator the water level in the tube is only up to where the ball is. If I turn the pump off and back on the tube will fill completely and the ball will rise a bit. After a couple of hours the water level will fall back to the spot where the ball was. There are no air bubbles anywhere in the system that I can see, neither flowing into our out of the flow indicator. I used thread wrap and pool grease on the connections and if I run a hose over the connection there is no change inside the indicator (so I would think there must be no suction leak on the in side of the indicator). Its just I would have thought it would be full all the time, so I want to see if maybe I need to remove the top and thread wrap grease that or call HASA and get a new indicator.
    Neil
    22,000 gallon vinyl in ground (17ft x 33ft) built in 1996, Pentair Whisperflo 1HP [2007] running into a Pentair Sand Dollar SD80 (75 GPM flow) [2007] and Rheem 266A Digital Gas Heater [2013], Liquidator [2013], full sun. And a UDS.
    22,548
    Re: Liquidator Flow Indicator
    It's common for it not ot be full of liquid. You can lube the o-ring on the cleanout plug on top of it, but I don't know if that'll do anything. The photo looks like it's not screwed down all the way.
    Does common mean, that's a normal issue people have but it needs to be fixed, or it's normal to be that way and its operating correctly?
    I'll loosen it up, grease it a bit and tighten it all the way down.
    Neil
    22,548
    Common (in this case) means there's nothing wrong with it being that way.
    Thanks for the clarification!
    Neil
