Results 1 to 10 of 10
Thread: Need a new liner. Any recommendations in North Alabama?
    May 2013
    Huntsville, AL
    31
    As you can read from the subject line, I need a recommendation for a pool/liner installer in north Alabama. If not, I will just call around. Thanks for any input.
    Fred
    20'x40' ~33,000 gallon IG vinyl liner pool. Sand filter. Hayward AquaRite SWG ( T-15 cell )
    TF-100 Test Kit and Taylor K-1766 Salt Test Kit
    22,548
    Re: Need a new liner. Any recommendations in North Alabama?
    Your best bet is to call a few pool stores and see if they will tell you who does their installs.
    What size and type pool is it?
    May 2013
    Huntsville, AL
    31
    Sorry, still new to site, I just updated my sig.
    20'x40' IG vinyl liner, chlorine pool with sand filter. When asking around, is there anything blatant I should steer away from?
    Fred
    22,548
    If they regularly do installs for the local pool stores they should be fine to use. You'll find out more once you talk to them.
    May 2013
    Huntsville, AL
    31
    Thanks, sounds easy enough. However, if it can be screwed up, I sure can find a way to do it.
    Fred
    May 2013
    Huntsville, AL
    31
    Rambler, I can't seem to find the right search criteria to find info for my next question. Since will will be replacing all of my water with a new liner replacement, I will need to know in what order to get my water balanced. I have read all the basic stuff on this forum. I can't find a sticky on this subject and can't seem to narrow down a search inquiry to find the right answer.
    Do I deal with alkalinity, chlorine levels, or CYA levels first? I wouldn't imagine trying to level them all out at the same time with virgin water is way to go.
    Fred
    22,548
    First order of business is to get a good test kit and test your fill water for everything except CYA. That way you know what you're putting in the pool and therefore can know what you're going to need to do to it. Chlorine is a given, as is stabilizer. pH may be a concern but you won't know that until you test it. After that, it's everything else.
    Stock up on some bleach and get enough stabilizer to get the pool to about 40 - 50ppm.
    When first starting new water add about 2 ppm FC each day until you get the CYA in there, then add whatever it takes to get to the target for the amount of CYA you added.
    Test the pH and if it's low test the TA. If the TA is ok (between 50-120 ppm) then adjust the pH with borax.
    If you'll post a set of test results of the fill water we can give you an idea of what you're going to need to do.
    May 2013
    Huntsville, AL
    31
    Rambler, thank you. This forum does seem to be quite awesome.
    The TF-100 test kit is already in the mail from TFTestkits. I got my tracking numbers in email on Friday.
    I am very excited to get this BBB method working.
    Somethings I am getting my head around at the moment. I see some people have a stenno pump, not sure what that is, or a Liquidator for auto-chlorination methods. What do you use and what would you recommend? Or would you just recommend doing everything by hand, which I am okay with.
    Fred
    22,548
    A stenner pump is a peristaltic pump used for injecting chlorine into the return line to the pool. The Liquidator is also an injection unit that injects the chlorine into the suction of the pump. Given the size of your pool I wouldn't recommend the Liquidator as it only holds 8 gallons of bleach so you'll be filling it every few days and the whole reason for having the injection system is convenience.
    I suggest that you manually chlorinate your pool for a few weeks to begin with. That gives you an opportunity to learn the in's and out's and personality of your pool. Once you ahve that down, then you can think about whether you want to automate the chlorine delivery or not.
    May 2013
    Huntsville, AL
    31
    I agree with your suggestion about manual addition. Even if I were to go the pump route, I would read about it until I was blue in the face before I ever purchased anything. It will be months before I do that.
    Fred
