Thread: Question about shocking
    May 2013
    Hartsville South Carolina
    46
    Good morning all,
    I have been reading pool school and the forums and have a question about shocking. I know the shock process says you don't have to shock on a schedule but even if if you keep your numbers in check do you still shock occasionally? Can you go a whole swim season and not shock? Does CC eventually show up even if you keep your FC level at optimal point? I guess I'm just trying to figure out what to expect as we are entering summer and should be in the high 80's and only to get hotter from here on out. Thanks for your input.
    Ryan
    23k gal, IG, vinyl, Pentair sand filter, 1 hp single speed pump, pool pilot digital swg, Hayward sharkvac. Built May 2013
    30,419
    Re: Question about shocking
    No. There is no reason to shock on a periodic timetable. You shock when your test results (or water appearance) tells you to.
    Many members go all summer without shocking. I hope to this year if I don't get careless.
    Butterfly's Avatar
    South Carolina
    10,045
    You can go years without shocking if you stay on top of things and there are no 'accidents' or dead critters or stuff like that.
    That is why we recommend only a couple of test kits. They put you in charge of your pool
    You're done SLAMing when:
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Only reason I've shocked my pool in 7 years is to winterize or go on an extended vacation like a week or more.
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by frustratedpoolmom
    Showoff!
    May 2013
    46
    Thanks all,
    Good to know.
