Thread: Aqua Trol no pump power. Power to panel is OK.
    Hi All,
    First post here. I have power to my Aqua Trol and showing lights. Everything seems to work except power to the pump. I bought a new pump relay from Digikey and replaced it on the main board to no avail. Anyone have any ideas to help me?
    Second question? There are 3 relays on the board. One for the SWG, one to power the pump, what is the thrid one for?
    Jun 2017
    Red Hook
    2
    Re: Aqua Trol no pump power. Power to panel is OK.
    I know this is old, but was it solved? I just opened my 30' above ground pool and my hayward pump was buzzing and then tripping the breaker. It then stopped all together. I bought a new pump but it would not power on. It plugs into my aqua trol generator. The generator is all lit up and seems normal. I plugged the pump into my main twist lock to test it and it worked fine. So the issue is with the the aqua trol not powering my pump. Did the bad pump ruin something?
    Thanks
    Shawn
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    426
    Here is the manual link http://www.hayward-pool.com/pdf/manuals/AquaTrol.pdf
    . Filter pump not running
    Check that the time clock manual switch is in the "auto" (center) position or in the
    "on" (top) position. If in "auto", then check that the time is correct (check am/pm
    by using the 24 hour indicator located near the 2 o'clock position) and that the
    trippers are in the "out" position.
    Also check the plug with a meter to insure there is voltage
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    poolside@haywardnet.com
