Results 1 to 15 of 15
Thread: Should I use a pool sucker pipette?
    Sullivan County, NY
    58
    I saw a guy at a commercial pool use a big turkey baster-like water sucker (ball on one end of tube) to get his water sample.
    This would be a nice way to avoid getting my arm wet when testing.
    Do people here use or recommend using one of these?
    Ideally, it would be well graduated (100ml?).
    Joseph
    Re: Should I use a pool sucker pipette?
    I use a 4 ft length of 1/2" PVC pipe...
    23,000 IG Plaster pool w/ spa, Pentair FNS Plus 48 DE Filter, Hayward RS1000 Main pump, Polaris booster pump, CPSC48 SWG, Legend pool sweep. Dallas, Texas, Full sun, Taylor K-2006
    Sullivan County, NY
    58
    That's perfect. I have CPVC around and that would make a zero cost, immediately solution.
    Thank you!
    Apr 2009
    South Texas
    177
    I use a turkey baster and fill a cup with water. That way I can go sit on the patio with my TF100 on the table and do all my tests with the same sample. The baster also makes it easy to draw water back out of the cup and squeeze the right amount into the vials. I have enough water left to rinse my vials and powder spoon.
    Just bought a new house in the country, no pool yet. :(
    Hot tub..500 gals..bromine
    TF100 test kit and speedstir
    Sullivan County, NY
    58
    Quote Originally Posted by erivette
    That's a great system -- much better than multiple dips into the pool for samples.
    Just any old glass cup?
    Just any old turkey baster?
    Thanks!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,034
    Quote Originally Posted by josephny
    Thanks!
    Not glass. Plastic only around the pool!
    I use a piece of PVC and a plastic two cup measuring cup with a pour spout that I bought at the pool store. Same thing - seated comfortably at the patio table. Just don't mistake the measuring cup for the coffee mug.
    Sullivan County, NY
    58
    Quote Originally Posted by Richard320
    Thanks!
    Got it -- of course, no glass makes sense.
    I tried the CPVC and it works great. Now I'll add a hard plastic cup and I'll be all set.
    Thanks everyone.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    The problem with a turkey baster is that you can't very far underwater and still stay dry (at least the basters I have seen). Generally you want to be a ways underwater to grab you test sample (18 inches is good). The pipe method mentioned above is much better imo since it allows for a deeper sample.
    Apr 2009
    South Texas
    177
    Mine seems pretty standard although it's stainless steel not plastic. And it's 12" long not counting the squeeze bulb. FWIW My tests, whether I stay out of water or put my hand in up to my wrist (the extra 6"), are consistent. No idea if the results would be different if I drew the sample from deeper than 2'. I'll try next time just for kicks.
    Jul 2012
    Dallas, TX
    179
    Pipette, great idea .
    I tried drawing my 1st sample using a 3/4" PVC pipe. I installed a PVC valve on my pipe instead of using my hand to cover the top of the pipe.
    It worked ok but it doesn't hold the water very well when I remove the pipe from the pool water before I'm able to release the water into my sample container.
    I think I read in another thread here were someone mentioned that a 1" PVC pipe doesn't work well as the inside diameter of the PVC pipe is too large allowing some or most of the water to drain from the pipe while lifting it out of the pool.
    Is that the problem with using a 3/4" PVC pipe? Would a 1/2" pipe hold the water longer?
    - Pool Type: 15k Gal Gunite IG non-SWG / Built 1988
    - Pump: Pentair Challenger / Sweep Pump: Letro Model LA01N .75HP Single-speed / 6 hrs-day (1 turnover)
    - D.E. Filter: OEM: Nautilus (Pentair) #NS 36 / 36 Sq Ft / D.E. Charge: 3.6 Lb
    - Pentair 4-wheel Sweep LL505G - Booster Pump runs ~2 hrs/day
    ozdiver's Avatar
    Oct 2014
    Spring, TX
    570
    Put a reducer on the end or a cap with a 1/4" hole drilled in it.
    40k gal freeform, IG pebblesheen, 9'x'6' raised spa, 2-1/2 hp Whisperflo, 520 sq/ft cartridge, Legend w/ booster, Intellibrite 5g in pool @ spa, Rainbow 320 Chlorinator(retired),
    Mastertemp 400k BTU, 3x3 hp Whisperflo Swimjets, 2x2 hp Whisperflow for 15ton moss rock waterfall, Intelitouch Controller, 850 sq/ft Travertine deck, Gas/Wood firepit,
    Autofill, TF-100 test kit w/ SpeedStir
    Jan 2012
    'burbs of Augusta, Georgia
    7,362
    I use whatever size PVC it is that lets my entire thumb pad to cover the end tightly while lifting the water out. I think it might be 1/2" but not positive (and too lazy to go measure, lol)
    Thimble's Avatar
    Apr 2013
    Wichita, KS
    93
    I use a Play Day saber pump squirter I found in the pool toys at Walmart. It's about 18 inches long and works like a big syringe. Gets the sample from the right depth, just happens to fill a Leslie's sample bottle perfectly, and the 98 cents price tag is cheap enough I don't worry about it getting broken or lost.
    It can even be used as a pool toy !
    15x30 IGP; 20,000 gallons; plaster
    Hayward SP2607X10 Pump; Purex Triton Tagelus Sand Filter
    Hayward Goldline T-Cell 15 SWG; Aquarite G1 Control
    Southwest Spas 400 gallon hot tub w/ozone
    TF 100 with speed stir
    Jan 2012
    7,362
    Quote Originally Posted by Thimble View Post
    Jul 2012
    Dallas, TX
    179
    Thanks for the ideas.
    I settled on the 4 ft length 1/2" PVC pipe with a PVC Valve at the top. The leakage, when drawn out of the pool before I open the valve into my sample cup, is slower than with the 3/4" PVC pipe.
