Results 1 to 14 of 14
Thread: Newbie Pool Owner
    Newbie Pool Owner
    TF 100 is on the way, here are the numbers I have with the kit I currently have, home depot jammie...
    FC 2.0
    PH 7.6
    TA 130
    We bought a house with an approx 10 yr old 20x40 inground. This is my first pool, so this is a learn as you go type thing. Already have been to the pool store where I dropped about $100 in "chemicals" to get it opened. Had to shock and add "alkalinity plus". Has an inline chlorinator thats running now, but I am going to go BBB as soon as the test kit arrives. After the shock, pool store said the water is perfect with the sample I brought them. But we will see.
    Every toy or hobby I have, I have a forum to go with it so I look forward to being a member here. Thanks already, wish I found this forum sooner!
    30K gal vinyl ig, hayward model S244T sand filter, hayward 1 HP pump, hayward chlorine feeder, hayward gas heater
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Newbie Pool Owner
    Welcome to tfp, flopalock
    No more alkalinity plus, your TA is already higher than ideal for a bleach chlorinated pool. Not a problem, it will come down on it's own eventually.
    How does your water look?
    Water is crystal clear, which is suprising given I pulled a garbage can full of leaves out of it after I took the cover off. It was a mess to say the least.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Do you have a measurement for cya?
    If you do and since your water is clear, then I would dose to the normal chlorine level for that cya level (see the poolcalculator.com recommended levels section) until your kit comes. Once the kit comes, run a full set of tests and post them.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,974
    Welcome
    What he said^
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Welcome, looking forward to your TF-100 test results
    The kit i have has an acid demand test that tells me to add 3 pints of muriatic acid, from what i can tell. Its minimal accordind to the chart in the kit, so i think i might wait til i can test with the 100.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    If your ph is still 7.6, then it is unlikely that you need acid at this point.
    OK 100 in the mail after work and here is what I have:
    CL 1.0
    PH 7.5
    FC 2.0
    CC 0.5
    TA 140
    CH 170
    CYA 50
    I thought the CYA would've been a little higher given the auto chlorinator, but who knows what they were using. The CH has me annoyed since the guy at the pool store had me dump a bucket of something in the pool because the water was too hard. Now lemme go play with the pool calculator.
    Richard320's Avatar
    Jan 2010
    18,974
    Quote Originally Posted by flopalock
    CL 1.0
    PH 7.5
    FC 2.0
    CC 0.5
    TA 140
    CH 170
    CYA 50
    Is the water clear? If so, just jack the FC up to about 6 and go swimming.
    Crystal, probably given im running the filter 16 hrs a day. Im playing with cutting back on that though. Check my avatar...heheh
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Yep, other than FC, your numbers look good...lucky you on the cya level
    Now you have the knowledge which gives you the power...so never let them do that to you again
    So after jack up the fc to 6, how long do i wait to test again to see where its at?
    Richard320's Avatar
    Jan 2010
    18,974
    Same bat time, same bat channel tomorrow. (I hope you're old enough to get that)
    If it ends up below 4, target 7 tomorrow. You'll learn your pool's appetite quick enough.
