Results 1 to 8 of 8
Thread: Buttress leaning in while filling
    I have just finished installing my 15' x 30' oval pool. While filling I noticed one of my buttresses is leaning in (toward pool) 1 1/2 inches. I have about 6 inches of water in the pool. The wall is dented in slightly close to this area. Will this correct itself when it fills up and pushes buttress back? Thanks.
    15x30 above ground pool
    Hayward S180T Sand Filter with 1.5 hp pump
    Central Kentucky
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Buttress leaning in while filling
    Welcome to tfp, Redbridge89
    Is the buttress outrigger off the ground?
    Thanks. It was off the ground so I added wa little weight to hold it down. The buttress is still leaning. I believe the channel has settled from weight of water on tje pressure plate. When I was digging in this area there was a large rock I removed. I must not have done a good job filling this area in. Is this a problem that I need to fix?
    Central Kentucky
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    If it just settled under the pressure plate, you may be okay. If it settled under the post and/or outrigger, then you may have a problem. How is the height of the post verses the one next to it? You may have to put a long board on the the two posts surrounding the problem one to judge it.
    The post in question is 1/2 inch lower than the rest of the post on this side. It appears the settling is at the pressure plate. Do you think it would be safe filling up and keeping an eye on it? There is only a foot of water in the pool I could drain and re-level. Thanks for your help.
    Central Kentucky
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Without seeing it (or seeing pictures) it is hard for me to say. It seems like at 1/2" you may be okay, but if the post keeps settling, then there will likely be problems.
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    sounds like you might be ok, as suggested definitely keep an eye on it.
    Thanks for your help. I ended up taking water out and putting a concrete block under the front of the buttress. I hope it doesn't settle again. Thanks again.
    Central Kentucky
