Thread: Intelliflo w/ Intellichlor w/o Intellitouch
    Hello All,
    I have a question concerning my Pentair products:
    I have my Intellichlor wired together with my Intelliflo to a timer switch in my breaker. However, the pump works under the premise of constant power and an internal electronic timer, with a start/stop button, as opposed to the old way of the external timer switch controlling the on/off's.
    Here's the issue: If I push the "stop" button or set the internal timer to shut off at a specific time, the chlorinator stays on. And if I set it up the old fashioned way of using the time clock in my breaker, the pump wont start because I need to push the "start" button.
    Without the Intellitouch system, how do I get both the pump and the chlorinator to function together?
    Thanks
    Location: Suburban Boston, Massachusetts ? Pool: 25K gal - In-ground / Gunite ? Pump: American Products 384484 Motor: 1.5 HP AO Smith Model SQ1152 ? DE Filter: American Products Titan CM #57025000 48 ft^2 ? Valve: American Products 2.0" Side Mount Multiport 501692 ? Lights: American Products Model R-300 BC 12-volt ? Cleaner: Hayward Pool Vac Ultra, 2005C
    Re: Intelliflo w/ Intellichlor w/o Intellitouch
    I believe that you need to set the pump into Manual mode and set the speed. As long as you don't turn off manual mode it should go back to the same setting each time it powers up.
    Thank you sir!!
    Mar 2007
    Murrieta, CA
    215
    Isn't this overcomplicating the issue?
    Why not just leave the Intellichlor on all the time. When the Intelliflo shuts off, then the flow sensor will sense it and basically shut down the Intellichlor.
    There will be a slight power draw for the IC controller, I'm guessing 5-10 watts, but that may be offset by using the Intelliflo the way it was intended, in automatic flow-control mode rather than manual speed-control.
    ~13500 gallon gunite pool, Pentair Intelliflo 4x160, Pentair 520 SF cartridge filter, Pentair MasterTemp 400 NG heater
    Pentair Easytouch with IC40 SWCG, Hayward Navigator on dedicated suction line
    Quote Originally Posted by peterl1365
    I was under the impression that the Intellichlor shouldn't be left running when the pump stops; even though there is a flow sensor. What I ultimately did was change my wiring configuration. Now, both the pump and SWC are on the same breaker but my pump is line wired (before the clock) and the SWC is load wired (after the clock). By doing this, there is a constant flow a juice to the pump and I can turn the SWC on or off without interrupting the pump.
