Thread: How to add bleach?
    Jun 2007
    MA
    165
    How to add bleach?
    We have a new 14ft Intex metal frame pool for BBB do I just dump everything in the water with the filter on or should I put the borax ect.. in a sock on the return?
    Cheryl
    14X42 Intex Ultra Frame
    Apr 2008
    Central Texas
    326
    The borax dissolves very quickly. I did mine by adding some acid, then some borax, then more acid, etc. to keep the ph from swinging to far. Walmart didn't have enough borax to do my pool all at once, so I finished up over a few days.
    26,000 Gallon Gunnite IGP
    2 HP Challenger High Head Pump
    60sf Nautilus DE filter
    Polaris 280
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    1,134
    You can broadcast the borax and baking soda. I put it in a measuring cup, break up large clumps with my hands, and scatter it over the surface. If I missed any clumps I usually break them up with the pole brush.
    The liquid chemicals I slowly pour around the perimeter holding the cup close to the water surface to avoid backsplash. I always have the pump running when I add chemicals and I also stir them in with the net at the end of the pole.
    The only chem I've put in a sock has been CYA because it takes a while to dissolve.
    AnnaK
    12,500 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
    I pour liquids in front of a return jet. The flow from the jet helps them mix in more quickly. Calcium needs to be broadcast across the surface of the pool, but many other powders are easier to pre-dissolve in a bucket and then pour into the skimmer.
    Jun 2007
    Houston, Texas
    209
    Do you see any problems pouring bleach right into the skimmer? That way it will get spread during return??
    36,000 gallon IG Gunite (40 x 20), 1.5 HP Hayward pump, Pentair Nautilus NS-48 DE filter, 2 skimmers, 12 - (2 x 20) Fafco Solar Panels (Goldline controller not hooked up yet), Hayward Swimpure Plus SWG, Blue Pearl Robot cleaner. New Dr. Wellness X-12 standalone Lifestyle Spa.
    It is possible that there is some very very slight damage to the pump seal and some pool heaters if you pour bleach directly into the skimmer but many people do so none the less and have not observed any obvious problems. I prefer to pour bleach slowly in front of a return while the pump is running.
