Results 1 to 11 of 11
Thread: Can't raise FC
    Can't raise FC
    Water is blue/ green after shocking, it was black. I've been adding three gallons of bleach every night for last 7 days. Have chunks of green algae floating in it, they are starting to turn grey/white around edges. From what I've read in pool school I think I'm on right track just wanted any advice I can get. Test results have been about the same for a week except CC that has went from .4 to 1.4. Using Taylor K-2006.
    33ftx54" AGP
    Vinyl liner
    TA 110
    PH 7.4
    FC .8
    CC 1.4
    CYA 45
    22,543
    Re: Can't raise FC
    Welcome to TFP.
    The first thing to do is go from adding chlorine every night to adding it as often as you can. That will speed up the process a lot. Also be sure to add enough to get the FC to shock level for a CYA of 45 each time.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Can't raise FC
    I agree, hit it hard, testing and adding hourly if possible. Only adding once a night wont get you very far...
    Casey's Avatar
    SW PA
    10,427
    Re: Can't raise FC
    The sunlight is going to compete for that chlorine too. So, as stated above 2x, hit it hard during the day light hours.
    Re: Can't raise FC
    Ok thanks I'll do that. Knew sunlight used it up faster so I was only doing at night. Will start doing day and night.
    30,403
    Re: Can't raise FC
    If you have "chunks" of organic matter in your pool, you should remove them with a leaf net...pronto.
    Re: Can't raise FC
    Ok I have been removing with net, but of course everyday there's a new batch.
    30,403
    Re: Can't raise FC
    Then you are not killing it and need to maintain more chlorine. One of the essentials of getting your pool clean is removing all solids.
    Re: Can't raise FC
    Ok. Pool calculator says I need to add 7 gallons of bleach to reach shock level of FC. Should it be added all at once or spaced out over a few hours?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Can't raise FC
    Quote Originally Posted by spoon359
    All at once.
    You'll be rechecking and adding more in a few hours.
    [center:alojxrbo][/center:alojxrbo]
    Jul 2010
    Pt. Arthur, TX
    174
    Re: Can't raise FC
    Quote Originally Posted by Richard320
    All at once.
    Actually, with the numbers you've reported (OP) I'd check it every hour or two & add enough chlorine to maintain your FC to shock level. At first, it will be consumed quickly & as you go on it will take longer & longer to consume the same amount of chlorine.
    For instance, you may have to add another gallon after two hours. Then another gallon two hours later. Then half a gallon two hours later, then half a gallon two hours later. Eventually a gallon would keep you at shock level for the whole day.
    The test though, is how much chlorine you use at night. Once you wake up with the same FC level as you had when you went to bed, you can allow your FC level to drift down towards normal maintenance level.
    Custom Cloud shaped 19'x35' - Raised Spa 6' diameter
    Rainbow 320 Inline Chlorinator - Paramount Clear O3 Ozone Generator
    Hayward C4025 Cartridge Filter (Hayward CX880XRE) - Hayward Tristar 2 speed pump
    Hayward H400Fdn Heater, Hayward GVA-24 (valve actuators)
