Thread: What to do first or do it all!
    May 2012
    Northern Connecticut
    103
    Hi Friends,
    I'm kinda new to this and so far things have been good. Today after days of cold weather and inches of rain my pool is dirty and a a little cloudy.
    Here are my numbers
    FC. .5
    CC. O
    TA. 70
    CYA. 0
    Salt. 3400
    PH. 7.2
    My husband already threw in a gallon of 12 per cent bleach
    I put in a sock again for CYA
    Can I put in baking soda and borax too?
    Thanks
    Sandy
    24,000 20x42 double roman end in ground pool being built. Start date june13, 2012.
    Finished July 4th, 2012, sports pool, vinyl,SWG, DE filter, fountains. Heat pump,
    First Pool Ever!
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Re: What to do first or do it all!
    I wouldn't do either -just yet. Looks like your PH is happy at your current level of TA. Borates are an option. Just keep your FC level in proportion to your CYA level. Get your CYA level up to what is recommended in pool school for I "assume" your SWG? If you have one, please add it to your profile and any other pool equipment info you may have left out.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    What CYA level are you shooting for? Just curious.
    Jeff
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,058
    pH and TA are acceptable. Deal with them later.
    Get that FC up to the level it should be assuming the CYA is 100% dissolved.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Quote Originally Posted by Blessedwithfivekids
    Do you know when and how much CYA was added? I would recommend a starting level of around 30 ppm and see how the FC consumption goes for a while. You can always add more CYA, if needed. BTW, where is the location of the nearest major city to you? If you are in AZ or FL and your pool is in full sun much of the day, you might shoot for a higher initial CYA of around 50 ppm.
    I would give the pool an initial FC dose of ~ 4-5 ppm. Once we know your adjusted CYA, we can go from there.
    May 2012
    103
    Ok
    Thanks all
    When should I test for chlorine again? I vacuumed the pool and turned the fountains on to mix everything. The kids ant to swim but I want to make sure the chlorine is safe. I would like a CYA of 40 ish but all last year and so far this year I have had zero. Between last yer and this yer I have added 10 lbs of CYA crystals via sock. I just put the sock in again.
    I live in Connecticut and we haven't seen the sun in days! Today is going to be partly cloudy.
    First Pool Ever!
