Thread: Deck Build revels a problem
    Apr 2013
    Millington, Tennessee
    51
    Well, I started building my deck. After digging my holes for my footings yesterday I went out this morning and one of the holes closest to the side of the pool has about 3 inches of water in it. This particular spot is the lowest side of my pool so it would make sense that if my liner has a hole in it it would all run to this spot. I did find a little hole in my liner about the size of a pencil eraser cut in half. could this be where the water is coming from or is there a bigger problem?
    30K Gal 36'X54" AGP, Eco kleer 22 Sand Filter 55GPM, Installed June 2010, Waterway 1.0 Hp Pump (Installed April 2013), Taylor-2006 test kit, Previously Perma salt system, BBB Method from now on.
    Jul 2007
    Chicago, IL
    87
    Re: Deck Build revels a problem
    It's very possible. Little holes canleak a lot of water, especially if theyare towards the bottom of the pool and the weight of the water is forcing the water out. See if you can patch the hole with a piece of old liner or a kit from the pool store.
    28K, 20' x 40' IG - Vinyl Liner, Hayward DE Filter, 1.5HP Pump, 250K Hayward BTU Heater, Aquabot Breeze 4WD robotic cleaner
    Casey's Avatar
    SW PA
    10,444
    If you had a hole, yes. Water travels to the lowest point.
    Apr 2013
    51
    The hole is in the bottom of the liner. I also have a patch kit hanging in the garage. Going to patch it. Thank you.
