Thread: pump and SWG positioning off ground
    wolfy's Avatar
    May 2012
    Randleman, North Carolina
    33
    Another Question. I have a 3 tiered shelf unit. I want to put the intex cartridge pump on the 1st shelf, the SWG on the 2nd shelf and use the 3rd shelf for drinks etc.. next to the pool. Would there be any problems positioning the pumps this way. My new intex pool is filling up right now, hooray.
    16x48 Intex Ultra frame pool with swg
    Re: pump and SWG positioning off ground
    As long as the shelf is reasonably stable that should be fine. The only important limitation is that the pump needs to be below the water line, and it sounds like that won't be an issue. The pump will cause some vibration. Hopefully the shelf is stable enough that there won't be an issue with the drinks shaking.
    alanpaul's Avatar
    Aug 2010
    South Florida
    227
    Agreed, and if you're making martinis you're all set. ("Shaken, not stirred" 007)
    Alan in Wellington, FL - near West Palm Beach
    15,200 gal IG, painted plaster, 1988; 200 SqFt cartridge filter, 2013; 1.5 HP 1-speed pump (uprated), 2005; heat pump, 2005;
    soon to repair (dead) SWG AquaRite T-15 cell, 2005, and replace (dead) suction-side cleaner, 2005.
    Almost everything died this winter 2012-'13, and I know we shouldn't complain... but, Arrgh!
