Thread: concentrated chlorine... Help!
    The only chlorine available a walmart tonight is 33% more concentrated. 121 oz = 182 oz.
    How do I calculate???
    FC = 0
    ph = 7.5
    Shock goal is 15.
    Where do i start???
    20ft round; sand; AG; vinyl
    Vette's Avatar
    Jul 2012
    Ohio
    404
    Re: concentrated chlorine... Help!
    http://www.poolcalculator.com
    The concentrated (121=182) Clorox is simply an 8.25% concentration instead of 6%. So you type 8.25% into the calculator.
    11,700 gallon 21' round 54" deep all-resin AGP - June 2012
    Waterway 1HP 2-speed pump / 100 sq ft cartridge filter
    Hayward 150,000btu Natural Gas heater
    I use and recommend the TF-100 for testing
    30,419
    simply adjust the percentage in the box of the poolcalculator from 6% to 8.25%
    Jul 2007
    Chicago, IL
    87
    The easiest thing to do is to go to http://www.poolcalculator.com.
    Enter the size of your pool in gallons, your current FC level (0), your target FC level (15) and the percentage strength of your bleach (sounds like 8.25). The website will show the amount of bleach you need to add.
    28K, 20' x 40' IG - Vinyl Liner, Hayward DE Filter, 1.5HP Pump, 250K Hayward BTU Heater, Aquabot Breeze 4WD robotic cleaner
    Thanks!! I have used the calculator since the beginning but just didn't know for % of the chlorine. Now I see the 8.25% on the jug. thanks again!!
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Quote Originally Posted by phyllis
    Where do i start???
    http://www.poolcalculator.com/. In the yellow-banded FC section at the top of the page, input 8.25 in the box where it says "Add of % bleach. It's between the "of" and "%". It will tell you how much of the 8.25% bleach to add to reach your target FC. Also, be sure to enter the size of your pool in gallons, your current FC level, and your target FC level
