Thread: Leveling problem with 22' pool
    A few weeks ago I began setting up our new 22' pool. We had a 15' last year. I needed to raise one side of the yard to level the ground. After building a retaining wall and adding 8 yards of dirt, I rented one of those compactors and had the ground nice and hard. Then I had a guy come out and finish leveling the ground and he used a tamp when he was finished.
    Set up the pool and it rainined while we were filling it up. Now the pool if full and the leggs are sinking into the ground causing the water to run over the top. So I drainined the water some to prevent that from happening. I tried to jack up the pole by using a car jack and then Iadded a 2x4 block under the legg and that didn't help.
    I read people were using patio blocks and having great luck. But myquestion is this. Won't they break and put meright back where I am? Seems I can only put it under a few inches so it son't be under the liner, is that okay? Is there some other way to do this?
    thanks!
    Jim
    Vette's Avatar
    Jul 2012
    Ohio
    404
    Re: Leveling problem with 22' pool
    This is why building up is not a recommended way to level the ground. The patio blocks are used under the uprights to give a solid foundation. My pool has the level ground with concrete blocks placed under the uprights for support. Having an extremely unlevel pool (especially one that water is spilling over!) is incredibly unsafe.
    11,700 gallon 21' round 54" deep all-resin AGP - June 2012
    Waterway 1HP 2-speed pump / 100 sq ft cartridge filter
    Hayward 150,000btu Natural Gas heater
    I use and recommend the TF-100 for testing
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Is this a soft sided pool are or a steel walled pool, if it's steel walled you can't jack it, it will need to be taken down and leveled properly.
    Using a patio block will spread the weight, may or may not work for you.
    Bottom line is that it sounds like the site wasn't compacted properly.
