Results 1 to 9 of 9
Thread: Cleaning algae stains from 15' Intex pool
    I drained my pool this week, realizing that it was completely out of hand with algae and leaves in the bottom. We did not have a good cover strategy over the winter.
    At any rate, after draining it, there are algae stains that aren't coming off very easy. We've removed the poles so we can get to the lining a little easier to clean.
    Any suggestions?
    Thanks
    [attachment=0:362biyej]921585_10200540831977668_130258526_o.jpg[/attachment:362biyej]
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Cleaning algae stains from 15' Intex pool
    Fill it up, follow the steps in "How to Shock your Pool" in Pool School - (upper right corner) then keep your FC at the upper end of your recommended range - See the CYA chart link in my sig - and the stains will fade over a few weeks.
    Vette's Avatar
    Jul 2012
    Ohio
    404
    Do as directed, but also brush the pool daily. It's a good workout and it'll scrub that algae off.
    11,700 gallon 21' round 54" deep all-resin AGP - June 2012
    Waterway 1HP 2-speed pump / 100 sq ft cartridge filter
    Hayward 150,000btu Natural Gas heater
    I use and recommend the TF-100 for testing
    Quote Originally Posted by frustratedpoolmom
    So.... am I wasting my time scrubbing with a scrub brush and bleach...?
    When we set it up initially, one side (foundation ground) wasn't leveled out, so this has been a great chance to get that fixed!
    Oh, noticed a small leak on the very bottom liner is that something I need t try and figure out and patch? Thanks!
    Vette's Avatar
    Jul 2012
    Ohio
    404
    Definitely patch the liner
    11,969
    Yes, patch it before you fill if possible. Yes with organic stains constant chlorine level will fade them just fine (and save you some energy .
    Whats the best way to ID a very small hole.... on the bottom liner with no water in it?
    Read the CYA chart, and reviewed shock process. Was hoping to find some alternative methods that may be a little lower costing. Any advise there?
    11,969
    This is the lowest cost methods for maintaining pools on the market. Once you reach shock level, with a fresh fill, you only have to do that once. Let it drop to normal. Say your CYA is 50. Keep your FC at a 7 or 8 for a week or so, and nightly you are talking about is adding one half of a small jug of 8.25% bleach. You could use generic, like from Aldi for about $1.30 a day or less it will cost you, to keep it at that level for a week.
