Thread: What pressure should I expect
    Just turned on pump, there is gauge on the cartridge filter, it doesn't work, I have one on order, what pressure should I expect in a typical system?
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: What pressure should I expect
    There really is not a typical pressure other than 0-30 PSI.
    Mark
    May 2009
    Youngsville NC
    395
    Every combination of pool, pump, filter, and piping can all affect what pressure you will see as your "clean" and "dirty" pressures. About the only rule you can count on is that this site recommends that you clean your filter when the pressure is 25% greater than your "clean" pressure.
    16x32 IG 19,000 gallons, Pentair 1.5 hp Energy Efficient Superflo pump (348024),vinyl liner, Chlorine dispenser, Hayward S-244T sand filter
    ok, that's a rule of thumb to follow if the pressure drops 25% clean change.
    SkyKid's Avatar
    Apr 2013
    Upstate South Carolina
    137
    Quote Originally Posted by Nova13
    No if the pressure rises 25%
    Take for example 10 psi clean backwash at 12.5 psi
    14600gal, In-Ground Fiberglass, Haywood s244t Sand Filter, Jandy Apure35 SWG,
    Haywood 2 speed 1hp pump, Haywood Pool Shark, TF-100 Test Kit http://tftestkits.net/
    Pool School http://www.troublefreepool.com/categ...etting_started
    Never been Pool Stored Thanks to TFP
    right, tks
