Thread: Advice on getting chemistry on track
    I have owned a pool now for 4 years and have recently decided maybe I should start taking better care of it
    I would like some advice on how to proceed because my chemistry is out of whack. Here are my test results:
    FC 15
    CC 0
    pH 7.5
    TA 200
    CH 650
    CYA 100
    I am also fighting a minor mustard algae problem. I was in the midst of shocking (hence the 15 FC), but realized it might be better to take care of the CYA first by draining some water.
    I read about how to lower the TA with acid and aerating.
    As you can see my CH is sky high and i need to drain water. Should I drain the entire pool or is a partial drain sufficient?
    Thanks for the help. This is a great forum.
    Keith
    20K gal IG Gunite with spa on same system
    Nautilus Stainless Steel 48 sqft DE filter
    1.5 hp Hayward MaxFlo pump
    30,421
    Re: Advice on getting chemistry on track
    Welcome.
    If you could drain about 40% of your water, Your CYA would be manageable and your CH and ALk may improve as well. Test your fill water for a good indication of what to expect.
    Once your CYA is down to 60 or less, you'll be much more successful with your battle with algae.
    Thanks for the reply! I will try this tomorrow.
