Thread: Re: table of FC loss percentages
    Re: chem geek's table of FC loss percentages, posted 07/14/2012
    My recently purchased house came with an 18,000 gal. pool and a CYA level off the chart. I drained 7,000 gal. and refilled, but CYA is still about 150, according to Leslie's. (Leslie's tells me that all other water chemistry #'s are OK.)
    At 150 CYA, the Pool Calculator gives me a FC goal of 11-18.
    Applying chem geek's 7.7% FC loss per day, I calculate that, if I start at FC 18, six days later my FC level will still be slightly above 11. Is this correct?
    Re: Re: table of FC loss percentages
    Yes, and no. Your calculation is correct. However you need to understand that the info in the table is just an average value across many pools. Every pool is going to be different and actual chlorine loss can be much higher or much lower than the nominal level. Chlorine loss varies with many factors, including water temperature, amount of sunlight, clouds/haze, time of year, shading by trees, number of people swimming, amount of wind borne debris entering the pool, and so on.
    30,421
    As you read further in the forum, you will find pool store testing is simply not to be trusted. I would never dose my pool based on a pool store test result.....CYA especially.
    Thanks for confirming the numbers. Now I need to test the water frequently and get a feel for how my other factors impact the FC loss.
