Thread: Dumb question - tool to loosen salt cell caps?
    I'm taking over maintenance of my pool equipment, and since my Jandy salt cell is giving me an error code, I want to take out the salt cell and clean it, which looks very straightforward.
    Except that with all the force I have, I can't unscrew it and get the two end caps off. Both are incredibly tight. (Yes, I've read the instructions that they don't need to be more than hand-tight, but I'm not the one who last tightened them.)
    Any hints for this newbie on loosening them? The caps seem to have indentations on them, hinting that maybe there is a tool that's built to loosen these?
    [attachment=0:29kkligy]photo.JPG[/attachment:29kkligy]
    Los Angeles (San Fernando Valley)
    15k gallon in-ground (IG) pool (I believe it's plaster)
    DE filter (Heyward), using cellulose instead of DE
    Jandy APURE1400 3-port salt cell
    Re: Dumb question - tool to loosen salt cell caps?
    A strap wrench often works well.
    Mike_W's Avatar
    Aug 2011
    Orange County, California
    142
    I'd also go the strap wrench method, but if that doesn't work, Channellock makes some nice pliers for "oil filters/PVC".
    http://www.channellock.com/oil-filter-pvc.aspxfilter
    I got mine on Amazon for about $15. Don't use it to tighten it up, though
    Mike
    ~17' x 34' IG pool with attached spa - 20500 gallons - Gunite with a "pebblesheen"-ish finish
    Jandy iAqualink with iPad and Jandy PDA remote - Pentair IntelliFlo VS 11018 Pump
    AquaRite SWCG - Pentair SMBW 4060 DE Filter - Really Old Raypak heater
    "Wall-E" an Arneson-Hayward Navigator - A couple of Jandy/Zodiac WaterColors LED Lights - Blue-White F-1000 Flow meter
    susa's Avatar
    Oct 2010
    Deep South
    578
    Have used something simple like this
    Thanks all. A strap wrench did the trick. It was a little tricky to figure out (the instructions said to look for a nonexistent arrow, and there's at least 4 different ways to use the thing) but eventually it worked and I got my salt cell loose.
    Tonight, we clean!
