Results 1 to 11 of 11
Thread: uv light
    uv light
    How good are uv light systems in reguards to controling cc level ?
    Erica
    15'x30'x52" Oval Johhny Weissmuller AGP
    Hayward Power-Flo LX 1hp Pump
    Hayward Pro-Series High Rate Sand Filter
    Aluminum Sundeck and Fencing
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,396
    Re: uv light
    In an outdoor pool their effect in close to nil. The sun does a much better job of burning off CC, and if you keep your FC levels in the correct range based on your CYA level you should not have a problem with CC.
    Love TFP? Become a
    TFP Supporter!
    Feb 2008
    Denton, TX
    5,061
    Re: uv light
    For an indoor pool, they are pretty helpful since you have no sunlight.
    Re: uv light
    I have 2 indoor pools 95000 gal
    44500 gal. the bather load in the 44500 is huge.
    Both are indoor.cc has been a major issue.also
    Have a 2000gal hot tub that within one day after a full drain I will see 0.6 cc
    Very hard to keep the cc in check. All body's of water are located on a very busy sports club.im looking for the best way to keep the cc below 0.2 at all times.
    Erica
    Re: uv light
    UV is a good choice in that situation. Adding MPS at closing time each day can also help, though MPS is not as complete a solution as UV since the CC level can go up too much during a single day sometimes.
    Vette's Avatar
    Jul 2012
    Ohio
    404
    Re: uv light
    Yes, UV would be good but make sure to not undersize it.
    11,700 gallon 21' round 54" deep all-resin AGP - June 2012
    Waterway 1HP 2-speed pump / 100 sq ft cartridge filter
    Hayward 150,000btu Natural Gas heater
    I use and recommend the TF-100 for testing
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: uv light
    Welcome to TFP!
    Re: uv light
    Thank you for the input. I think i will try the uv on the hot tub this week. I drained the hot tub last night and with in 15 hours i had a 0.8 cc not good,
    we are open 364 days a year and close only 6 hours per day so it is very difficult to fight the cc level.how do other indoor pools/water parks ect, deal with it?
    Erica
    Re: uv light
    The four main possibilities are: UV, ozone, MPS, and very high FC levels. UV works well, but can be a little expensive. Ozone needs to be sized and installed properly, which is rare, and is not so good indoors because of air quality issues. MPS can work well in low and medium bather load situation, but gets overwhelmed at higher bather loads. Very high FC level don't completely work and tend to cause problems (like hair loss).
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: uv light
    There is also significant water dilution, aeration strippers (removes volatile compounds), high capacity feeders (responds quickly to bather load so doesn't get behind in chlorine demand), microfiltration (removes dead skin cells and other particles better than sand filters), coagulation/flocculation with filtration (need slower vertical sand bed filters -- the rapid-rate horizontal sand filters just blow through coagulated particles), adsorption onto granulated activated carbon (part of the DIN 19643 method, but requires adding chlorine afterwards since it is removed in each circulation pass).
    If you have biofilms, especially in the sand filter that is not uncommon in commercial/public pools, then there are biofilm inhibitor and removal products such as sphagnum moss, Aquafinesse, Spa System Flush, Ahh-Some, Multizyme (added directly to filter), etc.
    None of these are needed in typical low bather-load residential pool situations, especially for outdoor pools.
    There really needs to be a forum for commercial/public pool operators so that you can share your experiences and best practices, similar to what we do here at Trouble Free Pool for residential pools and spas.
    May 2013
    Deep East Texas
    79
    Re: uv light
    I think good air circulation is also important for any indoor pool facility and CC. I think i read something on USA swimming website indicating that as combined chlorine is oxidized into the air it has the potential to drop back into the water if the air circulation in the facility does not remove/replace air regularly. My facilities use large industrial fan equipment for this purpose; since we dont have dehumidifiers.
    In ground 25,000 gallon - vinyl liner - Sand filter - residential pool
    Also maintain two commercial 190,000 gallon competitive indoor bromine facilities -9x Sand filters
