Thread: todays testing
    Liteguy's Avatar
    Aug 2011
    Cave Creek, AZ
    49
    todays testing
    Hi Guys trying to get this dialed in, close but very high CH
    FC=4.0
    CC=0
    TC=4.0
    PH=7.5
    T/A=110 This is parked at 110, cannot get it lower no matter how much MA I dump in
    CYA=30
    Salt=3440
    Borates 80
    CH=3000, I was in disbelief, re did the test, same result. Using last years chemicals, could these be too old? Pool calc said replace 91% of my water. That aint gonna happen as I would need to truck it in for like $500
    So any ideas? Water does get replaced upon evaporation
    Steve-Liteguy
    13K Pebble-tech Pool, ECO pump, IntelliChlor SWG, DE
    Re: todays testing
    Did you really use 300 drops (or 120 drops if using a 10 ml sample) of titrant?
    Did the sample turn purple at any point?
    Lowering TA can take a while. Also, if your fill water is high in TA and you frequently need to top off evaporation, you may never get it lower than that.
    Liteguy's Avatar
    Aug 2011
    Cave Creek, AZ
    49
    Re: todays testing
    I must be havin' a bad math day-SORRY-DUH
    Used 30 drops times 10=300, So looks like this is OK
    Steve-Liteguy
