Results 1 to 7 of 7
Thread: How to measure chemicals???
    I know, a dumb question. I've been using a measuring cup but I assume when hth says 8 oz....they mean 1/2 pound. If that's the case, how do you folks measure out your chemicals?
    Thanks in advance!
    Intex Ultra Frame 14' 48''/Intex .5hp Sand Filter 1600gph
    Re: How to measure chemicals???
    Ha, found the answer on this video, guess they do mean fluid ounces.
    [youtube:1mjtigpt]2B7dOxUj_Ng[/youtube:1mjtigpt]
    Measuring cups measure fluid oz, scales weigh oz weight. Instructions for solid chemicals normally give measurements by weight, while liquid chemicals normally give measurements by fluid oz. The Pool Calculator presents measurements both ways (in most cases).
    Jul 2010
    Raleigh, NC
    60
    So a dumb follow-up question but ... at this point all I have is a plastic measuring cup (from the kitchen dept at WalMart)....
    Using CYA granules for example - if my measuring cup said 32oz, that is 2 lbs, correct?
    26' x 52" Intex Ultra Frame (14,667 gallons), Hayward Matrix 1hp 2speed, Hayward ProSeries 21" sand filter
    1.5" PVC piping with in-wall skimmer, TF100 test kit
    City water in Raleigh, NC
    Jul 2010
    Raleigh, NC
    60
    Pls see my dumb question above ...
    The pool calculator said I needed to add 78 oz by weight or 82 oz by volume. So my kitchen measuring cup is actually measuring by volume, but is this accurate for non-liquid chemicals? For example - when it shows 32 oz, does it really mean 2 lbs of solid chemicals?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Quote Originally Posted by karenkolby
    http://www.poolcalculator.com/ will give you both weight and volume. Measuring cups are always volume.
    Jun 2013
    Fallsburg, NY
    258
    Or just get a kitchen scale and a large bowl. I picked up a cheap one at Walmart that weighs up to 11lbs in 10ths of an ounce. Put your bowl on the scale and push Tare to 0 out the weight of the bowl and start pouring until you have the right amount.
    8638 gallon 20'x52" Intex ultra frame round AG. 2650 gph Intex Sand Filter. Intex krystal Klear SWG. (newer model that includes copper ion generation) Hayward 1091LX skimmer, Kreepy Krauly lil shark. Taylor K-2006 w/speed stir and sample sizer. New this year, Intex PureSpa - dichlor-> bleach method for sanitizing.
    New pool, 16'x36' (approx 18000 gal) in ground pool, Haywood DE filter
