Thread: painting the bottom of waterfall black - to help heat pool?
    Jul 2009
    Massachusetts
    188
    backstory: we rarely turn on our heatpump - only once/season to make sure it still works .. our pool is heated through our solar cover and our waterfall. Sometimes the water that flows off the waterfall is like bath water because the cement (i think) gets so hot from the sun. So, we were thinking of painting the base of the waterfall black since the pool could be warmer (it hovers around high 70s and low 80s).
    is that crazy? Is there even a type of paint that would be recommended for cement that is in contact with pool water all the time?
    thanks,
    patty
    25,000 gallon gunite pool with waterfall (built 2000 - owner as of 2009), Aerotemp / Aquacal heat pump AT12000-A, Hayward DE4800 Filter, AOS UST1202 Motor, Hydro-King T104P201 Timer, Meyco pool cover, Pentair Model 320 Auto Chlorine Feeder. Located in Massachusetts.
    Re: painting the bottom of waterfall black - to help heat po
    That will help, but I don't think it will make a very significant difference in the water temperature.
