Thread: Type of brush?
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    334
    Type of brush?
    What type of brush do you guys recommend? I have an in ground pebble interior. I've been using a plastic bristle brush for a couples years. I do have a slight mustard algae buildup that I'm currently prepping my pool chemistry for shocking.
    ~15k gallons, 3'-5'-4' Figure 8 Shape In Ground
    Wetedge Satin Matrix Interior (Pebble)
    Paramount In-floor System
    Pentair IntelliFlo VS 3050, Pentair Triton II TR100 Sand Filter
    Pentair Intellichlor IC40 SWG
    thehowheels's Avatar
    Apr 2013
    SoCal
    120
    Re: Type of brush?
    Several folks on here have recommended the Wall Whale, which I am interested to try. Unfortunately I just purchased a plain-Jane nylon brush, which is working okay for me in the mean time.
    Matt
    9k gallon, plaster, IG. Raised spa w/ spillover into pool. AO Smith Century Centurion / Purex Triton WisperFlo 0.5 HP, Hayward 1.5 HP (spa), Polaris 1-516-01 1.5 HP (blower). Hayward DE3620 36 ft2 72 GPM DE Filter, Polaris 145 cleaner. Pool built ~1980.
    Trouble-free, BBB since: April 25, 2013
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    334
    Re: Type of brush?
    Wow that's quite the contraption! I will have to search out more postings on that, thanks
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Type of brush?
    Nylon is for vinyl, fiberglass, tile, and plaster that is less than one year. (Plaster includes any exposed aggregate and marcite finish, btw!) Combo brushes are for older plaster. All stainless are for algae (very stubborn green algae and also the ONLY brush for black algae.)
    You CAN unscrew the Wall Whale from the nylon brush it comes with and screw it on a combo brush if your plaster is over a year old. Newer plaster is really too soft for anything other than a nylon brush.
    You're done SLAMing when:
