Thread: Liner Lock for Beaded Liner
    DonW's Avatar
    Jun 2008
    Central IL.
    96
    Can anyone comment on the effectiveness of Liner Lock for a beaded liner? Opened the pool this year and was welcomed by not only sparkling clear water, but also 4 feet + of liner separation from one end of the pool. Aaarggghhhh! OMG! Now what? I started to look for the panic button. Some quick research on the forum and hot water from the tap, 2 1/2 hours of patience and help from a neighbor along with theses babies, the liner was back in the track.
    When I installed the liner 5 summers ago it was a hot sunny day with plenty of sunshine. Lots of give to the liner that day. 2 days ago not so much. My fingers are still sore from pulling on the liner while the neighbor used these bicycle tire repair tools to push it back into the bead receiver an inch at a time. The business end was the smooth end, not the notched end. If I were a pool installer, these would be my go-to tools for jumped beaded liner repairs. I suppose some teaspoons with rounded ends would work also, but these are also angled a bit and fit nicely into the palm of your hand.
    Anyways, any thoughts on Liner Lock so this kind of "fun" doesn't happen again?
    18' x 33' AGP
    16,715 gal.
    200 lb. Sand Filter w/Hayward PowerFlo MATRIX 1.5 H.P. 2 Spd. pump
    Stenner Injection Pump System
    Re: Liner Lock for Beaded Liner
    We have a section of our pool where the gap is too wide because of concrete settling and experienced the same problem. A short section of something like this solved it: http://www.inyopools.com/Products/03800 ... 7Aod_WsAWQ
    16x32 Oval In-ground Vinyl, ~17,000 gallons, Hayward 1hp Superpump, Hayward S245T Sand Filter
    Worn out sand? sand-filter-expert-help-t30049.html
    Drain the easy way: cyanuric-acid-blues-draining-pool-t43843.html
    http://tftestkits.net/splash-page.html , pool-school/chlorine_cya_chart_shock , pool-school/shocking_your_pool
