Results 1 to 9 of 9
Thread: New to forum....pool won't clear
    Been using shock alot! Have 30000 gallon inground vinyl pool, we cover in the winter due to leaves. When we opened it up we used flock, added pH, alkalinity, shock, algeaside. It was nearly clear then we had a bad storm, added more shock! Found this forum yesterday.... We added baking soda to raise the ph/alkalinity and added stabilizer.. Was starting to get clear then once again the rain hit last night!!!!! The pool is so cloudy and almost has a green tint, but of course rain for most of the day!!!! HELP!!!!!!!! Feel like we are just pouring money down the drain. Any suggestions would be greatly appreciated.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: New to forum....pool won't clear
    Audie:
    Welcome to TFP
    Quote Originally Posted by Audie
    That's exactly what you are doing if you are adding chemicals to the pool without good test results. Can you post some test results and tell us what you are using to test with?
    I would discontinue using the floc and algaecide. If you have algae, the algaecide is of no value. Plus if it's copper-based, that could lead to metal staining.
    My overall suggestions at this point:
    • 1. Post test results and tell us what you are using to test with.
      2. If you don't have one of the recommended test kits, I would order one quickly if you are serious about getting out in front of managing your pool.
      3. Read the Pool School articles. Things will begin to make sense more quickly than you probably can imagine.
      4. When you need a break from step 3, spend some time manually removing as much debris as you can from the pool, Then repeat step 3.
    Using hth 6 wy test strips
    Results
    Th 400
    Fc 3/6
    Ph 7.2
    Ta 120
    Cya 0
    Just tested....woohhoo the rain has stop for a few minutes.
    Jun 2007
    North Carolina
    82
    I'm surprised you have no CYA if you've been adding a lot of shock. That's how I get CYA into my pool. Either that or stabalizer. Are you using bleach or actual bags of shock?
    27' ABG
    Sand Filter
    Bags of shock. We are wanting to switch to the BBB method ASAP!
    30,426
    Exactly when and exactly how much?
    Added stabilizer yesterday along with the baking soda.
    30,426
    exactly how much?
    12lbs of baking soda and one bottle of hth stabilizer/conditioner. Since the ph/alkalinity was extremely low.
