Results 1 to 7 of 7
Thread: Time Vs. Keeping A Higher CL Level
    Pool slowly turning from pea green to blue but cloudy. Running pump at high speed 24 hrs per day, scrub liner except bottom drain area until I can see it, and pool solar cover on during daytime to minimize chlorine burn off. Do shock harder or give it more time?
    Day 1 - Pool opened and pump started. Color was dark green.
    Day 2 - Added stabilizer (6 lbs). CYA went from 0 to 50. Few hours later added 4 gallons of CL (22 ppm).
    Day 3 - FC 11 ppm. Added 2 gallons (11 ppm) back to 22
    Day 4 - FC 18 ppm. Added 1 gallon (5.5 ppm) back to 23.5
    Day 5 - FC 20 ppm. Added < 1 gallon (4 ppm) back to 24. CYA check and it 50.
    Day 6 - FC 19 ppm. Added < 1 gallon (2 ppm) back to 21
    Day 7 - FC 16 ppm. Added 2 gallon (11.5 ppm) back to 27.5
    Day 8 - FC 21 ppm. Added 1 gallon (5.5) back 26.5
    Chlorine tested and added on night time.
    1 gallon = 5.5 ppm
    CYA of 50 states shock requires 20 ppm
    PH normal after initial adjustment before shocking and looks good daily.
    ALK tested on Day 7 and was 170.
    Vinyl, Inground, 23,000, sand filter
    KK
    Kenbob
    inground, 23,000 gallons, vinyl liner, sand filter, 2 speed Whisperflo 1.5 HP, gas heater
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: Time Vs. Keeping A Higher CL Level
    Are you only adding chlorine once a day? As it gets used up, the algae can start reproducing which slows things down.
    You are doing just fine. There is no need for higher FC levels, that will just use more total chlorine to do the same job.
    You want to see daily improvement in the water clarity. This is often easiest to judge by looking at a ladder or stairs. If you are seeing a daily improvement then all is well. If you stop seeing any improvement then it is time to try something new.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    kenbob57:
    I would give it more time. The shock FC targets strike a balance between killing off organics while not being overly harsh on your pool and equipment. Keep in mind that you need to test several times a day to keep FC within the recommended shock range. One tweak I would make is to concentrate your testing/dosing at night as much as you can . The nighttime approach eliminates FC loss due to sunlight and thus makes more efficient use of your chlorine. However, that is not a license to ignore things during the day.
    Smykowski's Avatar
    Sep 2011
    3,065
    I agree with Richard. Maybe try testing and dosing twice a day instead of just once, but otherwise I think your process is textbook.
    All, Thanks for your inputs. I will adjust my monitoring / dosing to twice a day.
    Thanks again
    Kenbob
    Mar 2007
    San Rafael, CA USA
    12,082
    When clearing is slow and you have a sand filter you can see how to Add DE to a Sand Filter to speed up clearing by catching finer particles more quickly.
