Thread: PVC Leaks
    Jul 2010
    Pt. Arthur, TX
    174
    PVC Leaks
    This weekend I decided to pipe around my heater. I bought a couple of 2" x 2.5" three way valves, some PVC, some PVC primer, & PVC Cement. I followed the instructions as best I could, but obviously not good enough.
    I've got leaks.
    So without ruining these two expensive valves I just bought, how should I go about fixing the leaks?
    Custom Cloud shaped 19'x35' - Raised Spa 6' diameter
    Rainbow 320 Inline Chlorinator - Paramount Clear O3 Ozone Generator
    Hayward C4025 Cartridge Filter (Hayward CX880XRE) - Hayward Tristar 2 speed pump
    Hayward H400Fdn Heater, Hayward GVA-24 (valve actuators)
    30,419
    Re: PVC Leaks
    Where are they leaking? You will have to post a pic or two so we can see what you are talking about.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: PVC Leaks
    If they are just very slow weeping kind of leaks, sometimes, but not always, hey will seal themselves after a few days.
    Jul 2010
    Pt. Arthur, TX
    174
    Re: PVC Leaks
    I appreciate the help guys. Found a couple of videos on youtube that demonstrated what I need to do... doesn't look very hard at all, I'll be able to salvage & reuse my valves no problem.
