Thread: DEgetting back into pool
    I just replaced the grids in my Triton nautilus 48 filter and am getting DE back in the pool.Thought for sure it was damaged grids. There is a small crack in the plastic bracket that the grids sit on. I just opened the pool, have backwashed once and am only half finished with sweeping and cleaning pool.Had new liner installed last summer new pump and new gasket on multiport. Please help.
    Living in Cyprus
    In ground overflow pool tiled 12m X 4m 19507 Us gals 16243 Imp gals
    1 Kw motor 15 cu m per min Sand filter
    I thought I saw the light at the end of the tunnel but it was just some PERSON with a torch walking toward me.
    I started out in life with nothing and I still have most of it left.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: DEgetting back into pool
    You don't see any tears in the grids?
    Are you "rinsing" after "backwashing"?
    No tears in grids I just bought them a week ago. I am rinsing after backwashing. I usually backwash and rinse about 4 times before everything is clear
    Living in Cyprus
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Depending on your filter design maybe a torn or pinched O-ring then.
    Ike
