Thread: Ball vs gate valves
    May 2012
    Danville, IN
    21
    Ball vs gate valves
    Need some expert advice. I've done some searching but not really found any good posts specific to this topic. What is the best valve application to use on the suction side - ball vs gate, brass vs PVC vs pentair/jandy?
    I currently have brass gate valves, but recently found one is sucking air badly. Attempted to repack it and found I can't get it busted loose, so looks like I need to replace. These have been in place for 10+ years so tempted to replace with same setup. I've heard ball valves are better but not sure how they will do long term. I don't know much about the Pentair/Jandy types, so not sure what to think with those. A quick check of pricing online shows all three are appear to be relatively close in price.
    I currently have three on/off valves, so not sure if I should consider a 3 way valve for the skimmers. Any advice or recommendation would be appreciated.
    25K gal IG Vinyl Ell shaped pool, Pentair SuperFlo 1.5HP single speed pump,
    Pentair SandDollar sand filter (Zeobrite), Pentai Intellichlor IC40 Chlorine Generator
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Re: Ball vs gate valves
    Well.... you don't need to make every mistake yourself.... Check these threads. You can probably find more using the search function (upper right)
    regular-pvc-ball-valve-vs-jandy-or-pentair-valves-t45257.html
    issues-with-losing-pump-prime-t59126.html
    I would never use either a ball valve or a gate valve. It is always worth using the Jandy NeverLube series or the equivalent from other companies.
    anguspoe's Avatar
    Jul 2012
    Kansas City, MO
    23
    The water main to my house was a cheap pvc ball, one basement remodel later......
    someone posted a side by side of the jandy vs pentair and the looked the same. Pentair just cheaper
    Vette's Avatar
    Jul 2012
    Ohio
    404
    Ball valves are a pain. After being in the sun, the cheap handles get brittle and inevitably crack off, leaving you with a little nub instead of a handle. Then you gotta keep a pair of pliers by your equipment pad. Tacky.
    Jandy valves are A+++++. Smooth turning, low head loss, and can be taken apart.
    11,700 gallon 21' round 54" deep all-resin AGP - June 2012
    Waterway 1HP 2-speed pump / 100 sq ft cartridge filter
    Hayward 150,000btu Natural Gas heater
    I use and recommend the TF-100 for testing
    May 2012
    Danville, IN
    21
    Thanks for the help and advice. I have three pentair valves on the way.
