Results 1 to 13 of 13
Thread: Start of my Stenner Build
    NoFear95's Avatar
    Mar 2013
    Phoenix, Az.
    138
    Was starting to work on installing my Stenner set up..
    -Purchased a 3ft tall aluminum powder coated fence post to use as a mounting point for the pump.
    -Purchased a 18x18' patio brick to put the Brewer barrel on.
    -Started running the intake hose....
    Have to wait till the pool gets a little more complete to install in the injection side. But I did get my plumber to install 2x ports for the chlorine and at some point later...acid injection.
    IG, 18K gallons, 100' Perimeter, 565 SF surface area, 980sf interior area, Max Length -36', Max Width - 16', Pentair 520 Clean and Clear Cartridge Filter, Stenner Chemical Injection System (Chlorine, Acid Coming Soon) , Pebble Tech - Blue Granite, Pentair variable speed filter pump, Zodiac MX8 Cleaner, Multi-Colored LED Lighting, Travertine coping & Decking, Boulder Water Fall....
    NoFear95's Avatar
    Mar 2013
    Phoenix, Az.
    138
    Re: Start of my Stenner Build
    More..
    22,553
    That's a neat looking install.
    I like the way you mounted the pump. Neat idea.
    NoFear95's Avatar
    Mar 2013
    Phoenix, Az.
    138
    Thank-you! It is kind of on hold until it gets depressurized with the finish/fill of the new pool.
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    subscribing.
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    Dallas, TX
    109
    Recently started mine, not quite as far as you are but I did plumb in my injection point- which is a lot closer to the pipe- so the end of the injector is flush with the inner radius of the pipe it's injecting in to. Although, now that I think about it, it will all be mixed in regardless...
    How is the dosing done? Is it set up to run continuous at minimum drip rate or on a timer? Or, do you have a transducer to measure the ORP or something?
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Watching this one... Want to learn how to build one of these... The liquidator is expensive for what it does.....
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    cnatra's Avatar
    Feb 2014
    Houston TX
    187
    what is that you're using for a tank ?
    23k gunite, Stonescapes Mini Aqua Blue w/seashell, Pentair CCP520 cartridge filter, 2 Pentair Intelli-Flo VS pumps, Pentair Mastertemp 400, Pentair EasyTouch 8+wireless controller, Silencer spa blower, 3 Intellibrite LEDs, Pentair Racer cleaner, Pentair 320 chlorinator
    my build http://www.troublefreepool.com/threa...-north-Houston
    Aug 2011
    Southern California
    188
    I used one of these. 15 gallon capacity.
    Purchased here- ULINE
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    This is my Stenner and tank!
    Jun 2014
    Cypress, TX
    6
    I know this is old, but I just received my Stenner pump and am looking at storage drums. Some have two bung holes on top, and I see yours has only one. Do you just refill by taking off the cap and pull it up around the hose. I think I'd want to disturb the hoses as little as possible. Also, I was wondering what you use for a timer or do you run a drip? Thanks in advance.
    14,990 IG plaster; DE Pentair FNSPLS 60; 6 lbs DE; 150 gal/min; 2 HP WhisperFlo 2 speed pump; built Feb 2002;
    640 gal spa w/ constant waterfall; 5' x 10' waterfall; Polaris 280 cleaner;
    Pentair 400 nat gas 34,000 BTU heater; in-line auto chlorinator tower (empty)
    Dec 2013
    apollo beach,fl
    36
    I'd go for the two hole ( i didn't think of that on my install). small for feed and leak return (i just drilled a hole for the leak return), use the large for filling. That said i only keep mine 1 or 2 turns tight, no problem really to fill. the hoses are heavy duty doesn't hurt disturbing them. I just unscrew mine and lift it up part way out of the way and fill.
    1987 16k gallons IG, Marbletire Marquis, ,Pentair superflo 1hp, Hayward s244t, Chlorine (working on stenner setup)
