Results 1 to 17 of 17
Thread: Spa draining when I put pool on spa mode
    May 2013
    New Orleans, Louisiana
    14
    So I have a pool with an attached spa. It's a aqualink I think. I have a remote control. It always worked fine. Today, I turned it on spa mode in order to heat it, and it started draining. It looked like it was draining into the pool. I turned everything off on the remote and tried again. Same thing. I lookeda t the panel and it looked normal. Any suggestions?
    The filters and saltcell were cleaned recently by some maintenance guys. I'm wondering if maybe they hit some switch or something I'm not aware of.
    15k, IG, gunnite, Pentair whisperflo, Pentair Clean & Clear Plus ccp520 Cartridge, Polaris valve actuator, Goldline valve actuator GVA 24,Aquarite Goldline electronic cell, remote control upgraded from Polaris Sol 1000 to a Jandy PDA Aqualink RS, spa attached with spillover, Built in 3/2004.
    22,549
    Re: Spa draining when I put pool on spa mode
    Sounds like a valve isn't switching or is leaking by allowing the water to be sucked from the spa and returned to the pool.
    May 2013
    14
    Do you know why it would not be switching? I took a picture of the valves when running ok in pool mode. There are 5 valves. The big valve to the left is the polaris, the big valve to the right is the goldline. The second picture is of the switches on the polaris.
    22,549
    In the mode you show, it looks like it's drawing water from the pool only and returning water to the pool and spa.
    When you switch to spa mode, does both actuated valves switch?
    May 2013
    14
    When I switched it to spa mode, just the valve on the left (the polaris) did a 180. The last valve on the right didn't do anything. Then shortly after the whole thing stopped working. I cant turn anything on at all. So now I'm trying to reach an electrician to see what's wrong with that. Hopefully minor. But when I get it to work, what should the spa mode look like when it's working right? Any suggestions on what might be wrong with the spa mode?
    22,549
    When it's working correctly, the valve on the left will switch opposite of what it is in the picture and the valve on the right will switch 90 degrees one way or the other (I suspect it will turn ccw).
    May 2013
    14
    If it's not doing that, does it mean I probably need a whole new valve? If so, any particular type recommended given the equiptment I have?
    22,549
    The first thing to do after getting the power back on is to flip the switch on the right valve and see if it will move. If it does it may be a matter of reprogramming it to be in the spa mode. If it doesn't, we'll need to do more troubleshooting.
    May 2013
    14
    I tried hitting the spa mode button on the panel before the power went out and the valve on the right (goldline) didn't move. I didn't see any switch on the valve itself. Is there supposed to be one? I only found switched on the left polaris valve.
    22,549
    It may be under the bottom, but there should be one I think.
    May 2013
    14
    So of course I can't find an electrician over memorial day to easily. I'm worried about the pool getting green without the pumps running. Any suggestions on what I can dump in there to keep it clean while the pumps are down? Can I buy shock and just dump it in without pumps? Any suggestions? The chlorine level is already pretty low, but the water is still clear for now.
    22,549
    You can pour enough bleach in there and stir it really well with a brush to get it stirred up.
    Have you checked the breakers? It may be just one tripped and resetting it may get you back running.
    May 2013
    14
    I checked all of the breakers. Then I got a hold of my electrician friend. He found a 9 volt battery that was dead inside the panel and thought at first it was that simple. But after replacing the battery, we still couldn't get it to turn on. He checked the fuse, and everything else. He thinks maybe the mother board is shot. He's going to call the manufacturer tomorrow. I think I upgraded the whole thing a couple of years ago, so maybe it's under warranty. I don't know. Cant remember who installed it.
    A
    22,549
    Good luck with getting it fixed. Post back when you get it up and running and let us know what it was and if that also fixed your spa draining problem.
    May 2013
    14
    Having more problems then I thought getting electrical fixed. My electrician drew a dead end calling the manufacturer and distributors. Not sure the problem. I have an aqualink control panel that originally came with a large remote control. I later upgraded it with some Jandy product. I can look up the info when I get back home, but my electrician thought I might have problems getting the parts. Someone at a distributor said there were a lot of problems and lawsuits with my system and it's not made anymore. Not sure if they meant the original or the upgraded product.
    22,549
    Post the parts and maybe someone here will have an idea what to do.
    May 2013
    14
    Should I pour shock in for now and stir it around? I'll post parts when I get home. So I came home and looked for the owner's manuals. The original system installed in 2004 was a Polaris Sol 1000. A few years later, the board burned out or something. Anyway, I bought a conversion kit. The manual says a""Polaris SOL/EOS Aqualink RS installation Kit". It is a pool/spa combination. This was installed a fewyears ago. It is now completely dead.My electrician checked everything out. It's not the electrical. He found the 9 volt battery inside the panel was dead and changed that. Nothing. He checked the fuses, they all seem good. Any suggestions/feedback on this system?
    Also, what should I add to the pool until I get the pump working? Shock? I have a salt system.
    PS: I inadvertently put AG in my signature when it should have been IG. Sorry about that.
