Results 1 to 8 of 8
Thread: First test TF-100
    chclark's Avatar
    Sep 2012
    Pittsburgh, PA
    51
    First test TF-100
    ok so here it is just got the test kit.
    FC 5
    TC 5
    CC 0
    PH 7.2
    TA 120
    CYA 60
    Doent seem to bad right? CYA high from granular triclor use I guess.... I just got some BBB and making the switch. Question is TA is high because i was using triclor, should I try to bring this down since im making the switch to Bleach? Or just leave it alone and get FC up to 7ppm.
    IG 16x32 Grecian - Vinyl - Approx 18k gal - 1 HP Hayward Super Pump - Pentair Triton II TR-60 Sand Filter - Hayward ColorLogic Light - Hayward H250FD Heater
    Re: First test TF-100
    Your numbers look fairly good. With CYA at 60, you don't want FC going below 5. TA is a little high, but I doubt it is high enough to cause problems. Unless you have problems with PH rising quickly, just lower the PH to 7.2 each time it gets to 7.8 until the TA level is in range.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Your vinyl pool doesn't care if you have low CH, but high CH can still cause scale. Better check that, too. Otherwise, looking good.
    chclark's Avatar
    Sep 2012
    Pittsburgh, PA
    51
    ok I'll get the FC up to 7, keep an eye on PH and do the CH test.
    30,419
    Is your water clear?
    chclark's Avatar
    Sep 2012
    Pittsburgh, PA
    51
    yes water is sparkling clear... CH was 190. Added 52oz of 10% liquid chlorine this AM. Just got the kit and trying to figure this all out... How long should i wait to do a full retest? I'll keep checking PH and chlorine daily
    30,419
    Well, it sounds like your pool is balanced and you have adequate chlorine to keep it sparking all summer. I think it is a good idea to do the pH and OTO chlorine test daily throughout the summer....perhaps a little less once you determine how stable your pool is.
    Most folks do the full battery of tests weekly. Since the testing is a bit new to you, I would suggest you test again in just a few days and see if you get similar results. Unless your results are way different from todays, I would go to the once weekly regimen.
    chclark's Avatar
    Sep 2012
    Pittsburgh, PA
    51
    will do thanks... the only test where I was a little unsure was the cya test so I did it twice and got very close to same results
