Thread: size for aqua rite cell
    amberjack
    Guest
    I bought a hose with a 20,000 gal pool. It has a aqua rite t15 currently. The cell has gone bad. Is there any benefit in paying for a t15 over a t9 ( made for up to 25,000 gal). There is a $100 difference. Would I have to run the pump longer with the t9?
    amberjack
    Guest
    Re: size for aqua rite cell
    House NOT HOSE
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    We recommend a cell rated 1.5 to 3 times larger than the pool volume. The t-cell15 is rated at 40000 gallons so that is a better fit for your pool then the t-cell9.
    amberjack
    Guest
    thanks, I found that info after posting my question. Has anyone had any experience with CompuPool replacement cells. Anyone know if they use the same materials in the cells. I like that they are clear, so you can inspect the cell more easily. The one for 40,000 gallons is $369.00
