Results 1 to 17 of 17
Thread: auto chlorinator vrs floatie
    Apr 2013
    henderson, nevada
    25
    I moved into my house a few months ago and this is the first time I have owned a pool. I have a service to maintain the pool until I can do it on my own.
    I have a rainbow lifeguard 320 auto chlorinator but my service does not use it. Instead they use a floatie with the tablets in there. My question is which is better?
    Some info on my pool, 28ft by 15ft with max 5ft deep free form concrete in ground pool with an elevated spa and waterfall. I have there intelliflo vers pump. I live in las Vegas.
    14.7k IG free form pebble with elevated spa and waterfall, 3HP intelliflo vrs 3hp , Hayward super 2 pump?, Hayward swimclear cartridge filter c4025, rainbow lifeguard 320 & floatie, pentair master temp 400 heater, Hayward pool vac ultra
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: auto chlorinator vrs floatie
    Quote Originally Posted by bulsworth
    Neither really since both use trichlor. See: http://www.troublefreepool.com/pool-..._chlorine_pool
    Apr 2013
    henderson, nevada
    25
    What do you recommend then?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    I am glad you asked I would switch to bleach/liquid chlorine. Pool school (link near upper right corner of each page) has a ton of info. Here is an article to start with: http://www.troublefreepool.com/pool-..._chlorine_pool
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Plain liquid bleach or liquid chlorine. Both are the same active ingredient (sodium hypochlorite). Liquid chlorine just has a higher concentration. These products do not add anything undesirable to the pool, unlike the pucks. Liquid bleach/chlorine is manually dosed by pouring it in a thin stream in front of a pool return .
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    [center:819q66gz][/center:819q66gz]
    Apr 2013
    henderson, nevada
    25
    Yeah i am reading through pool school so I can do this on my own soon.
    Now have to figure out how to put in the pool return
    Apr 2013
    henderson, nevada
    25
    So you guys recommend liquid chlorine into the pool return? Can I buy liquid chlorine at any store or online?
    Richard320's Avatar
    Jan 2010
    19,051
    Costco, Walmart, Target, grocery store. Or Lowes or Home Depot in the pool section they'll have 10 or 12% stuff. The freight to ship gallons of bleach would kill you!
    Apr 2013
    henderson, nevada
    25
    Thanks. Now back to figuring out how to get it into my pool return.
    Jul 2007
    Chicago, IL
    87
    Hi Bulsworth, all you have to do is to pour the liquid chlorine into the pool while standing above the return, while the pool pump is running.
    28K, 20' x 40' IG - Vinyl Liner, Hayward DE Filter, 1.5HP Pump, 250K Hayward BTU Heater, Aquabot Breeze 4WD robotic cleaner
    An off topic side conversation on sinking/floating trichlor tablet dispensers has been moved to here.
    Apr 2013
    henderson, nevada
    25
    Quote Originally Posted by Siamese
    Is the return the skimmer? How much do I pour in, assuming i can use the pool calculator and my test results to determine this?
    38,460
    No. The return is the jet of water shooting back into the pool.
    With accurate test results, then use poolcalculator to determine how much bleach you should add to achieve the desired FC level.
    Apr 2013
    henderson, nevada
    25
    I have 3 jets that shoot into the pool. Does it matter which ones?
    38,460
    The strongest or the one in the deep end would be my choice. This just asked the chemicals to mix in well before coming in contact with the pool surface.
    Apr 2013
    henderson, nevada
    25
    Thanks
