Thread: shock a pool start-up-when open it is clear and fc 2?
    Hello All Again!
    We opened our pool with our well. We do have a filter system on our water, does add salt though to it. Anyway, to our wonderful surprise, except for a dozen leaves or so, our water looked like the day we closed it. It had a FC level of around 2. Have kept it at 1-3, need to put bleach in, today at FC1 Thanks fellow BBBers!
    Does everyone shock, just in case for bacteria or algae when they open? I have maintained the FC since we opened. Pump has been running 24/7 for the last few days, and we have been vacuuming and keeping leaves and stuff out. Wondering if we should take it to 10ppm anyhow?
    Currently FC1 and PH7.8
    "VegMaPa" in the Midwest - a "NEWBIE"-opened pool July 2012
    AG Silverstone 24' Round x 52" -13,500GAL VINYL -ABOVE GROUND
    ClearWater Cartridge Filter CW65XL100SDBH (or is it W90, W120?) -Vortex XL150S 1.5HP Pump
    Hayward LP Gas Heater H150 .....LOVE TFP, crystal clear pool going on our 4th year!
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: shock a pool start-up-when open it is clear and fc 2?
    Quote Originally Posted by VegMaPa
    I don't.
    If you are concerned, you could take it up to your FC shock level and do the OCLT, but if you water looks good and if you do not have CC or excessive chlorine usage, then I personally wouldn't. It won't hurt anything though.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    VegMaPa:
    Congrats on a clean pool opening
    I'm with linen in that I wouldn't shock unless my test results dictated the need. I would, however, run a full series of test results and do an OCLT just to be on the safe side. You will need to know your CYA in order to properly dose with chlorine whether you decide to shock or not.
