Results 1 to 8 of 8
Thread: low filter pressure for DE4800 Filter
    Jul 2009
    Massachusetts
    188
    Hi, so i'm having filter woahs....
    after taking apart the grids in my filter, i found several tears. one large and a few small ones. I replaced one grid with a brand new one and the others, i patched by sewing wiith dental floss and using waterweld.
    after turning on my filter for the first time (this season) and immediately adding 4 cans of DE, the filter pressure is only at 13. two years ago, 20 was the normal pressure and i backwashed at 25. then last year, it dropped to around 15 and i backwashed at 20, but it worked so i didn't worry about it too much. this year, i thought after cleaning and fixing the filters, it would go back to 20 at least, but it's at 13 now. what could be the issues? should i be concerned that pressure is too low?
    thanks so much!
    25,000 gallon gunite pool with waterfall (built 2000 - owner as of 2009), Aerotemp / Aquacal heat pump AT12000-A, Hayward DE4800 Filter, AOS UST1202 Motor, Hydro-King T104P201 Timer, Meyco pool cover, Pentair Model 320 Auto Chlorine Feeder. Located in Massachusetts.
    Vette's Avatar
    Jul 2012
    Ohio
    404
    Re: low filter pressure for DE4800 Filter
    No DE is coming out of or has come out of the return, has it?
    11,700 gallon 21' round 54" deep all-resin AGP - June 2012
    Waterway 1HP 2-speed pump / 100 sq ft cartridge filter
    Hayward 150,000btu Natural Gas heater
    I use and recommend the TF-100 for testing
    22,550
    Have you replaced the pressure gauge or made sure it's reading correctly?
    Jul 2009
    Massachusetts
    188
    Thanks for the responses..
    I'm seeing a little DE in the pool, but that could be residual from last year - i won't know for certain for a day or so, i think. Would that explain the drop in pressure?
    Regarding the pressure gauge. how do I know if it's reading correctly? i didn't remove it this year, but i noticed one drop of water escaping the little taper end, so maybe it is losing a little pressure?
    I don't want to take apart the filter until the pool is clear. is that OK? is it less effective at a lower pressure? I think the pool will be clear in 2 more days so if i can keep it together until then, i'd rather take it apart then.
    22,550
    I suspect that the gauge is bad. You can change it at anytime. They're cheap enough to just change out if there's any doubt.
    I'd just keep running it. If it's not blowing debris into the pool, just let it run.
    Jul 2009
    Massachusetts
    188
    Thanks Dave -
    I think there must be other issues with my grids because i'm still getting DE in the pool (along with dead algae). I went ahead and ordered Gridsocks to cover the grids - so hopefully that'll fix my issue - and i'll go ahead and change the gauge too. Is that something i can get at home depot or do i need to get one from the pool store? I have a hayward DE4800
    thanks again
    Patty
    Jul 2009
    Massachusetts
    188
    btw, other than holes in the fabric, could there be any other reason for DE in the pool? is it possible i assembled the filter wrong? seemed pretty straightforward.
    thanks
    22,550
    Either holes in the grids or a grid not seated on the manifold are the common reasons for it to leak DE into the pool.
    You can get a gauge at the local home improvement store. A zero to 30 psi will be fine.
