Results 1 to 8 of 8
Thread: How many tablets to put in feeder?
    Guest
    Hi, all,
    This is my first post and I made an effort to read some articles within the Pool School. However, I might have missed something which is why I am posting here.
    (Using a HTH 6-way test kit):
    TC - 0.0
    FC - Unknown
    CC - Unknown
    pH - 7.5
    TA - 200 PPM
    CH - 220 PPM
    CYA - < 30 PPM (filled tube all the way and could still see black dot)
    I'm in the process of establishing the FC in my pool but I'm having some trouble. I'm supplying chlorine via a feeder filled with 1" chlorine tablets. At first, I filled the feeder with six 1" tablets. I measured the FC the next day and it registered less than .5 PPM. So, I doubled the amount of tablets to 13 the next day. I then measured the FC the next morning and there is still no FC registering. I have checked and the tablets are in fact dissolving and the 13 tablets that are in there are about have the size they originally were.
    Now, am I doing something wrong or should I just keep putting more tablets in the feeder?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: How many tablets to put in feeder?
    Welcome to TFP. I would stop using the tabs and start using bleach. The tabs add things like cya and acid.
    Read pool school some more to understand what BBB is about and think about getting a good test kit like the tf100.
    Jeff
    Guest
    Quote Originally Posted by pwrstrk
    Do you know where I can find out how much bleach to add to my pool? Is this info located in the Pool School? If so, where (I can't find it)?
    Vette's Avatar
    Jul 2012
    Ohio
    404
    You find out the range you need to keep FC at in Pool School. It's under Chlorine/CYA Chart. Then you find out how much to dose by testing with a good test kit (TF-100 or K-2006) and then entering the numbers into poolcalculator.com to find out how much bleach to dose.
    11,700 gallon 21' round 54" deep all-resin AGP - June 2012
    Waterway 1HP 2-speed pump / 100 sq ft cartridge filter
    Hayward 150,000btu Natural Gas heater
    I use and recommend the TF-100 for testing
    If your tab feeder is like mine, there should be a knob at the bottom of the feeder to adjust the amount of chlorine that is dispensed. The number of pucks in the feeder shouldn't matter as much as the setting of the flow adjustment knob.
    8.5k gallon IG pebble sheen play pool with Intellitouch control, Intellifo VF, IC 20, Rainbow tab feeder (not currently in use), Pentaire mystery cartridge filter with labels faded to the point I have no idea on the model, Intellibrite 5g LED light, Hayward Navigator. Adding IntelliPh and Crestron control next.
    Guest
    Quote Originally Posted by Vette
    Thanks Vette for pointing me in the right direction.
    Quote Originally Posted by dtlight
    Yeah, I checked the feeder and it's all the way open. I must not have enough tablets in the feeder?
    Vette's Avatar
    Jul 2012
    Ohio
    404
    Chlorine is getting into your water. But then it is getting used up by something. With low CYA it would be sunlight. If you had CC's, it would be organics. Could be a combination of both. I highly recommend getting a quality test kit. Takes all the guessing out. pool-school/pool_test_kit_comparison
    If you have a test kit like that, there should be a CC test. I would think that any kit that does CYA would also do the simple CC test. Look over the directions carefully to see if there is a CC test.
    Guest
    Unfortunately, I have the HTH 6-way test kit that doesn't include a way to test for FC or CC.
    However, I just ordered a TF-50 test kit since I already have the HTH 6-way test kit. For now, I'm going to shock my pool using the amount of bleach suggested by the pool calculator. This will hopefully keep any algae blooms at bay until I can test for FC and CC.
    Thanks everyone for the help!
