Results 1 to 8 of 8
Thread: cant get salt levels with taylor test kit
    so i am attempting to lower my salt level because i believe it to be high.
    i tested it the other day seemed high like 4000. i did the math needed to drop the water level about 2 inchs i dropped it 2.5
    I re-filled it yesterday
    today i go out and attempt to test but it seems to be clumping up a bit. I am using the swirler and not me just shaking the sample. the first test did give me a result looks like still 3800 i waited tested water again and no color change at all. went cloudy and stayed that way.
    could it be to cold?
    attempting to get salt to about 35-3600
    18,000g 27' x 52" AG, Proline cartridge filter, 1.5hp pump, ChlorEase CL02 chlorinator
    pool is a transplant from one location to my location and was just put up 4/5/13
    Location : Delaware its on the EAST COAST and yes its a state LOL!
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: cant get salt levels with taylor test kit
    Looks like the chlorease is fine with a salt level 3400-4000 ppm, so I would not worry about it unless the chlorinator is not working.
    22,548
    Which salt test are you using?
    Taylor
    22,548
    The K-1766?
    Did you throughly clean the vial prior to running the test? The only time I've had it look clabbered in the beginning is if I didn't clean the vial before running the test.
    totally clean. tried it 2 more times. first drop clumps up.
    22,548
    How old are the reagents?
    If they're not brand new, how were they stored over the winter?
    new kit bought last month
