Thread: Open in Ohio
    Vette's Avatar
    Jul 2012
    Ohio
    404
    Open in Ohio
    Opened the pool today with a brand new equipment pad designed by us made from the same deck boards used on the pool deck. The new pad was designed to fit the heater that we got this year. Water was sparkling as soon as the cover was off! Topped off the water, fired up the pump, and dosed with bleach and borax (PH was a little low at 7.2). Going full on BBB this year after using some tabs last year. CYA was perfect at 50 after topping off the pool. Should be a great summer! Water is only 55 right now, but that's why we got the heater
    First off, the equipment pad without all hoses hooked up:
    Here's with everything running!
    And I know y'all wanna see the water!!
    Sorry for all the ripples, pump was running on high
    11,700 gallon 21' round 54" deep all-resin AGP - June 2012
    Waterway 1HP 2-speed pump / 100 sq ft cartridge filter
    Hayward 150,000btu Natural Gas heater
    I use and recommend the TF-100 for testing
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Open in Ohio
    Looks excellent. Good job with closing.
    Jeff
    Vette's Avatar
    Jul 2012
    Ohio
    404
    Re: Open in Ohio
    Not sure why links broke, but they are fixed again. Pool opened at 52 degree water, it's now at 76 after running the heater a bit and having a lot of sun the past 3 days.
