Thread: Can I test my own salt level?
    Jul 2012
    south La.
    32
    My swg stopped giving me a reading on salt level. I don't know why. I also tried to adjust the t-15 number but I'm getting strange symbols like a busted calculator screen. The pool store gives me a salt reading but i don't want to go there any more
    30,000
    IG (in ground)
    vinyl
    sand filter
    SWG
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    Re: Can I test my own salt level?
    The Taylor salt test is recommended. Good results as long as you follow the instructions.
    http://tftestkits.net/K-1776-Taylor-Salt-Test-p31.html
    15'x30' IG - Roman-style - 14K - Pebble Fina Classico
    Filter: Jandy CL460 Pump: Jandy Stealth SHPF1.5 SWG: Jandy AquaPure 1400 Cleaner: Jandy RayVac Test Kit: TF-100 w/SpeedStir
    Chlorine/CYA Chart----Extended Test Kit Directions----SLAM
    Jul 2012
    south La.
    32
    Are u implying that its difficult?
    30,000
    IG (in ground)
    vinyl
    sand filter
    SWG
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    Not really. If you are comfortable doing the other tests (CYA, CH etc.) then you will be fine. If not, then the salt strips are an acceptable alternative.
